Results 1 to 10 of 41
Thread: suitable diffs for moderately powerd 86s
    Jul 2010
    clay
    wa
    balcatta
    Default suitable diffs for moderately powerd 86s
    hey guys. im about as green as it comes when it comes to diffs. iv just broken a diff in my sr turbo 86.
    it has a tarago e series 4.3 ratio diff. im having trouble locating a replacement center. my question is, what centers are compatible with that housing (if any)? also a friend suggested i get an rn40 rear axle but again having no luck.
    i work away so i dont have alot of time on the net to research. what would be my best bet for a reliable rear end?
    any info would be greatly appreciated.
    Gone
    Joel
    Picton
    F series is the way to go, 7.5" center.
    you will find them in mkII corona ( same track as 86) or in Yr22 tarago +50mm?? cant remember. they will take punishment all day, tried, tested and proven.
    Mechanical LSD's available as well from all popular Japanese manufacturers.
    Can't really go wrong.
    Ps just to make it clear, this center won't fit in your E series.
    Jul 2010
    clay
    wa
    balcatta
    when you say mkII corona do you mean a corona or x60? also what model/yr?
    Veteran johl's Avatar
    Johl
    my f series should be for sale if i sell my shell tomorrow. all modified to bolt in and painted black. let me know if your interested and i'l let you know if i can split it from my shell tomorrow
    Jul 2010
    clay
    wa
    balcatta
    what ratio is f series? and how much would u want for it?
    Mt Macedon
    F series is good. As Sundee says. There is also MS112 Crown F series which has huge wheels bearings and good discs.
    G series (Hilux diff) is bigger and stronger and may be overkill. Supra discs can be fitted.
    Then there's R31 too.
    All will require mounts changed, tailshaft changed, handbrake cable modified/changed, etc, etc. If you're away with work alot then it may be worth buying something ready to go, or taking parts to a shop and saying "make it work".
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Johl, you have PM
    Current Cars:
    Johl
    im not 100% but i think it was 4.3. im after $1200 as that is what i paid
    Moderator Sam-Q's Avatar
    Endeavour Hills
    which model Tarago had the E series?
    The r31 diff works but it's a bit wide and quite heavy
    Mt Macedon
    Quote Originally Posted by Sam-Q View Post
    YR20 and 21 at least. YR22 got the F.
  1. Suitable Daily
    By KE-BAB in forum Cars or Parts Wanted
    Last Post: 23rd February 2008, 02:36 PM
  2. More masses of 86s
    By tricky_dan in forum General Topics (No Technical Questions)
    Last Post: 20th December 2007, 01:22 PM
  3. looking for suitable LSD mounts
    By sprinters_r_mad in forum Cars or Parts Wanted
    Last Post: 22nd December 2006, 10:42 AM
