Results 1 to 7 of 7
Thread: RWD 4age motors 7mgte
    Senior Member Jordain's Avatar
    Jul 2010
    Jordain
    Penrith
    Default RWD 4age motors 7mgte
    Hey got a few motors/parts that are taking up way to much space in my garage.
    1) I've got a complete 4age smallport. Has RWD water setup on it, Cut and shut manifold, Clutch, lightened flywheel, ARP flywheel bolts, bigport cams, has good compression on all cylinders. It did blow a little bit of smoke on cold start but went away once driving. The head was reconditioned a few months ago.
    $1500
    2) I've got another smallport, this one I built. It's a smallport block, Blacktop crank, rods, pistons. Got new bearings, ring's, acid dipped block, all parts where cleaned, the head was shaved. Compression is 11:5:1. has bigport cams in it. This motor is a long motor has no bolt on parts. It needs big end bearings as I think it's spun a bearing.. either way it's got a light knock on startup and when you rev it hard. Needs rebuilding...
    $1000
    3) 7MGTE i bought for my soarer about 10 year's ago. Paid around $2k from ichibarn but .... it's since had parts stolen of it etc.. It did run... no idea if it still does... $200 come take it away... worth $100 in metal lol.
    4) ADAPTRONIC E420c, Blacktop ITBS, T3 adaptor, 70mm trumpets, Vacuum block, Injectors, rail, regulator, FULL custom loom to plug into standard ae86 body loom, or I've labeled it to be easily wired into any car. Theres 4 wires to connect.
    $1300
    Jordan - 0468403713
    Quote Originally Posted by Blaike View Post
    locker in, starting a badass 7ac build
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    bitch
    Senior Member KAYE70's Avatar
    Apr 2012
    aidan
    nsw
    kellyville
    are these sports motors by any chance? they look pretty damn sporty
    also whos that mad kent whos in the engine bay in the 2nd photo? hes off the rails
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Quote Originally Posted by lolwat View Post
    bitch
    I second this statement.
    bursting ovaries since 92'
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    No more OT posts please.
    Senior Member Kevspec's Avatar
    May 2010
    Kevin
    Central Coast
    What's missing from 7mgte?
    Jul 2010
    Jordain
    Penrith
    ct26 and manifold.. bout it
  1. WTB: 7MGTE supra injectors plugs and 4age plug
    By stealth86 in forum Cars or Parts Wanted
    Last Post: 28th October 2012, 12:41 AM
  2. rwd small port 16v complete with rwd 4age harness sydney
    Last Post: 24th July 2010, 05:12 PM
  3. WANTED: 4age Rwd Water Pump Pully And Rwd Alternator Bracket
    By BIGPORT71 in forum Cars or Parts Wanted
    Last Post: 26th May 2010, 10:11 AM
  4. 4age 100kw complete motors
    By sprinterman68 in forum Car Parts For Sale
    Last Post: 3rd June 2007, 10:32 PM
  5. 4age valve retainer - other motors?
    By sr_rolla in forum Technical - Questions
    Last Post: 19th May 2006, 08:30 PM
