Results 1 to 10 of 11
Thread: euro junka e30
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    Default 3s beams e30
    thought i'd put up a build thread on my newest project since it's a bit different to the other cars that I’ve owned in the past
    it’s a 1988 318i e30 always loved these things but I’ve always bought a Toyota instead up till now, this one was so cheap I couldn’t say no
    <How it looked when i got it>
    this car will be replacing my old ke70 that i crashed at Calder adgp last year
    This is what it looked like after i got some wheels and chopped the springs and welded the diff very unique mods for a bmw
    But what worked on a kesev didn’t work on the bimmer and it lost its shit at this point it wasn’t looking to good on the side of the road out in the middle of no where with a smashed alloy sump
    so I got some proper coilovers and raised it up a bit and drove it again this time with a lot more success as much as I like low cars it’s just not going to happen with where I live
    mods so far include
    320i rear swaybar
    xyz coilovers
    16x9 -0 all round with 195/45/16
    fog lights
    Welded diff
    Nathan
    Lilydale
    So Boss!
    When is a 1j getting fitted?
    Gavin
    kilmore
    Don’t tempt me if I didn’t already have a beams sitting in the garage at the moment I probably would have gone a 1j
    this is the plan at the moment I’ve got a really clean 3s beams sitting in the garage at the moment with a 3vz 4runner bellhousing bolted up, then a 2009 r155 5speed bolted up to that it looks to be the same as a late model r154 but the input shaft is shorter the ratios are different and the shifter is also different more forward
    I still need to sort out a starter motor clutch flywheel and also need to get my hands on a jzx100 shifter it looks like it should bolt up to the r155 gearbox
    3 out of the main bellhousing bolts line up and all the dowel pins do so there shouldn’t be any alignment issues just need to tig up that last bolt hole so it fits
    this show how well the r155 shorter input shaft fits with the beams just need to get a spigot bearing as it use to be an auto if it all fits it will be good
    Nathan
    Lilydale
    well thats a way better idea than a 1j! well played. adaptronic, quads, crazy headers =win.
    Gavin
    kilmore
    wrong again I’m going to turbo it that’s the reason it got an r155 attached to it the bottom end looks the same as the turbo 3sge in the Caldina except the pistons are different for higher comp this is from what of read so if I’m wrong let me know I’m just going to boost it and see what happens but that will be ages away got plans for a cage bucket seat and get it on track first
    Senior Member Water Boy's Avatar
    What coilovers did you get. Complete kit or did you need to cut and weld?
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    Well this is fucking awesome.
    quit hatin get bakin!
    Gavin
    kilmore
    got some xyz coilovers in a complete kit with base height adjustment and damper adjustment its got a complicated strut so I’ve had to cut the bottom of it off and weld on the bottom of the coilover onto it ill get some pic’s up soon
    Also picked up a custom flywheel today that should suit the gearbox ill have to see when I get a clutch and starter motor
    ryan
    this looks epic, what wheels are these?
    Gavin
    kilmore
    this is what flywheel looks like holds a 225mm clutch i think it was based off a beams flywheel to convert early 3sge's to rwd
    got a cheap clutch off a 1985 hilux it had the right bolt pattern and the 21 spline input shaft fitted perfect
    just a quick pic off the front coilovers as i said i would, i had to cut the bottom of the strut off and then press on a weld on sleeve that holds the coilover to the knuckle
    also wanted to see what it would look like with a turbo on the side very tempting indeed
  1. Euro Motorsport thread
    By Gunner in forum Youtube Chan
    Last Post: 27th May 2010, 10:03 PM
  2. Junka AE92, just out of rego, needs alot of love
    By Gunner in forum Cars for Sale (Toyota Only)
    Last Post: 15th November 2009, 07:46 AM
  3. euro drift
    By tin can in forum Offtopic Discussions
    Last Post: 9th January 2009, 10:24 PM
  4. euro drift
    Last Post: 5th January 2009, 06:56 PM
  5. U.S.A have Euro H/Lights
    By dr1ft-pig in forum General Topics (No Technical Questions)
    Last Post: 1st September 2005, 11:17 PM
