Results 1 to 10 of 12
Thread: spacing a crossmember down - how low can i go???
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    Default spacing a crossmember down - how low can i go???
    Just wondering what is the maximum I can space a crossmember down before running into problems with steering etc
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the way it works is that the further you go down the disproportionally more out it gets. So anything you add is affecting it, however.... this can be completely offset with running taller roll center adjusters. Dave from AJPS sells a type of steering ball joint that has no grease nipple on the bottom. This allows for much more room before the bottom of the outer steering joint hits the rim of the wheel.
    Here's the formula for you:
    Height of roll center adjusters needed = Lowered height from unsagged original ride height + crossmember spacer thickness
    Feb 2010
    Jordan
    Cheers for the reply Sam
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    Quote Originally Posted by Sam-Q View Post
    with that formula will that give you the best lower control arm angle with stiff suspension or will you benefit from having the control arm closer to level cause the movement of the arm will be reduced by lowering the car I’ve never run rca’s before but I know that I get no bump steer at standard height and a lot when the control arm sits level when lowered
    Glenn ke_70's Avatar
    Clay
    Barossa!
    it effectivly the effect on the front geometry same as lowering your car
    just moves the other side of the lca down instead of up.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    dont forgot your sump will hang down lower
    dose
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Quote Originally Posted by KE70GT View Post
    Sorry off topic but ^ this is interesting, have thought about this.
    The natural angle of the LCA is to work in the most effect range, but with standard boat suspension, nearly all cornering would bring the outer LCA (LCA taking all the load) near level anyway?
    Endeavour Hills
    That's an interesting viewpoint Deeken although I don't think the stock suspension would lean bad enough to get the same angles many of us are seeing in the suspension.
    Speaking of all this I have wanted for some time to get some real long RCA's made up, pity I don't have the time to do it.
    Endeavour Hills
    this will give you the original geometry that Toyota thought was the most ideal for the vehicle when they designed it. How critical this is and how it still suits a sports suspension is the big question.
    May 2012
    ACT
    belconnen
    The angle that the LCA sits at is something manufactures rarely screw up. They tend to ruin the suspensions ability to perform by messing up other angles that are more difficult to change.
    What I'm curious about is why anyone would want to space the crossmember lower in a car, aren't you just raising the minimum height the rest of the front end can sit at?
  1. Spacing Crossmembers Effect on Steering
    By PRIMRK in forum Technical - Questions
    Last Post: 16th January 2011, 04:44 PM
  2. Replies: 8
    Last Post: 29th April 2010, 02:10 PM
  3. spacing head to turbo n/a 4age
    By mick in forum Technical - Questions
    Last Post: 14th April 2010, 12:03 AM
  4. 4age waterpump pulleys - Bolt Spacing
    By LittleRedSpirit in forum Technical - Questions
    Last Post: 24th January 2010, 06:28 PM
  5. 4ac carb bolt spacing
    By shakes in forum Technical - Questions
    Last Post: 24th March 2008, 02:35 PM
