Results 1 to 1 of 1
Thread: s13 sr20det motor+gerabox
    May 2011
    Shannon
    Default s13 sr20det motor+gerabox
    S13 SR20DET BlackTop
    MOTOR:
    TOMEI Poncams Type R -Duration:256 Lift:11.5
    TOMEI rocker arm stoppers
    TOMEI metal head gasket
    Alloy pulleys (new)
    Stainless steel exhaust manifold (new)
    3" Stainless steel dump (new)
    550cc injectors (reco'd)
    TOYOTA Coil packs /built in ignitor
    S15 Garett t28bb (reco'd)
    Billet alloy turbo flange adaptors (new)
    TURBOSMART Fuel pressure regulator FPR800 (new)
    EARLS braided turbo lines oil/water
    Stainless nuts,bolts used everywhere that didnt require High Tensile
    Clear cas cover (new)
    SPEEDFLOW hose
    SPEEDFLOW push fittings&adaptors everywhere possible
    All new Studs, Nuts,Bolts,Washers and Spacers
    Head,Block,brackets,water lines,and thermostat housing have been chemically cleaned&Ceramic coated
    Plenum has been sand blasted
    Stainless nuts,bolts used everywhere that doesn't require High Tensile
    ARP flywheel bolts (new)
    Freshly machined flywheel
    EXEDY stage 2 racing clutch kit
    • EXEDY Racing Stage 2 Pressure Plate
    • EXEDY Racing Stage 2 Thick Cerametallic Clutch Disc
    • Release Bearing
    • Pilot Bushing
    • Part Number: 06950B
    • Torque Capacity: 363 ft-lbs
    • Disc O.D.: 240 mm
    • Spline Teeth Count: 24
    Genuine NISSAN VRS gasket kit (new)
    Genuine NISSAN turbo gasket kit
    (new)
    Gearbox:
    S13 SR20det 5speed
    *Rubber fork seal (new)
    *Rubber selector boot (new)
    *EXEDY release bearing
    (new)
    *Chemically cleaned and ceramic coated
    $3300 neg
    located in QLD brisbane birkdale
    more pics available soon
    genuine buyers only call 0431462007
Name:	shannon photos 304.jpg
ID:	27918Click image for larger version.
Name:	shannon photos 291.jpg
ID:	27919Click image for larger version.
Name:	shannon photos 316.jpg
ID:	27920Click image for larger version.
Name:	shannon photos 302.jpg
ID:	27921Click image for larger version.
Name:	shannon photos 308.jpg
ID:	27922Click image for larger version.
Name:	shannon photos 298.jpg
ID:	27923Click image for larger version.
Name:	shannon photos 297.jpg
ID:	27924Click image for larger version.
Name:	shannon photos 300.jpg
ID:	27925Click image for larger version.
Name:	shannon photos 049.jpg
ID:	27926Click image for larger version.
Name:	shannon photos 321.jpg
ID:	27927Click image for larger version.
  1. Sr20det s14/15 motor
    By sundee in forum Cars or Parts Wanted
    Last Post: 9th October 2012, 01:41 PM
  2. sr20det motor with garrett 2871r
    By turn69up in forum Car Parts For Sale
    Last Post: 6th December 2011, 06:02 PM
  3. Nissan SR20DET Motor and Gearbox
    By smurf in forum Car Parts For Sale
    Last Post: 17th August 2010, 09:59 PM
  4. fs: Blacktop s13 sr20det motor $1500
    By d_spec84 in forum Car Parts For Sale
    Last Post: 17th January 2010, 09:31 PM
  5. s13 sr20det
    By ca1871 in forum Cars for Sale (Not Toyotas)
    Last Post: 30th November 2009, 05:29 PM
Tags for this Thread
