Results 1 to 2 of 2
Thread: WTB 4age 20v silvertop crank angle sensor
    Sep 2012
    Tristan
    Koongal
    Default WTB 4age 20v silvertop crank angle sensor
    WTB 4age 20v silvertop Crank angle sensor
    i've put a microtech lt10s onto this 4a and i wired up the cas wrong now the car is flat out going past 4000 rpm, Throwing Cas codes at above idle rpm and running really retarded timing.. so trying to hunt down a crank angle sensor for it! don't need the dizzy cap even as i'm using coil packs now
    Cheers twisty
    Sep 2012
    Tristan
    Koongal
    i should also say, that the cas is now wired correctly but i think its broken a transistor inside maybe
  • Similar Threads
    1. crank angle sensor 4age rwd
      By van_ in forum Cars or Parts Wanted
      Last Post: 25th August 2011, 11:55 PM
    2. (QLD) 20v microtec ecu, loom, map and crank angle sensor
      By FLT LNR in forum Car Parts For Sale
      Last Post: 23rd July 2010, 07:33 PM
    3. WTB: 20v ecu, loom and crank angle sensor
      By FLT LNR in forum Cars or Parts Wanted
      Last Post: 14th October 2009, 05:00 PM
    4. 4age crank angle sensor
      By Daim in forum Technical - Questions
      Last Post: 12th February 2008, 09:22 PM
    5. Crank Angle Sensor Setup on 20v?
      By ke25 racer in forum Technical - Questions
      Last Post: 30th October 2006, 12:10 AM
