Results 1 to 9 of 9
Thread: Engineering an SR20DET in AE86 in VIC.
    Mar 2010
    Luke
    MELBORUNE
    Default Engineering an SR20DET in AE86 in VIC.
    Hi Guys,
    Hope I've posted this in the right section.
    I am looking to drop an sr20det into an ae86.
    Is it engineerable? Vic Roads give you much hassle?
    Wanting to hear from people who have done this before, or similar ie. into ke70/ae71
    Any information is appreciated
    Thanks
    Luke
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    as far as i know an engineers cert in vic is only valid for 30 days ?
    if this is correct not worth the hassle imo unless your happy with just tracking it once you get done
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    Nah Dave once a car is engineered its engineered forever. If you change or add parts though they aren't 'engineered' per se although you can get away with it. You could engineer a car for 15x8 wheels which means you can have any 15x8's.
    Paul
    VIC uses the NCOP as the guideline so the SR20DET will be fine. The 30 day limit on the engineering report just means that you have to get it registered within 30 days of getting it done. Just the same as a RWC in most states.
    Paul
    Elite rthy's Avatar
    Leo
    Tulla
    id check with the mob who u will be getting the rwc from to confirm if they will pass it
    Mar 2010
    Luke
    MELBORUNE
    Thanks for that Paul. Just have a mate offering me his sr20det package outta a ke70 and it's too good to pass up.
    Just need to speak to engineer and see how much its gunna cost to engineer it.
    Mmm good point rthy. I had a Mazda 1300 13bt and no one wanted to go near it for RWC but I think a piston motor will be fine.
    Mt Macedon
    - Find engineers list on Vicroads website
    - Ring and discuss your plans
    - Get advice and do as they suggest
    Shouldn't be too hard, but can be time consuming and expensive depending on what the particular engineer wants to see of upgrades and tests.
    Feb 2013
    Trent
    how's this all panned out be interested to know if it was done and who engineered it ?
    May 2010
    Catherine
    I engineered mine after I got pinged for it having a 4age but same process. There are only a few on the VASS list which do 4 cyl modded cars, most do trucks.
    Pretty much it just went through brake testing and noise testing with few other meager tests. Only took a couple days and $.
  1. [vic] ke70 sr20det
    By tshaw44 in forum Cars for Sale (Toyota Only)
    Last Post: 23rd June 2012, 07:46 PM
  2. SR20DET AE86 white VIC
    By adam_loves_hachi_roku in forum Cars for Sale (Toyota Only)
    Last Post: 19th March 2012, 03:28 PM
  3. Vic - 180sx, sr20det, clean.
    By TRAV-GZE in forum Cars for Sale (Not Toyotas)
    Last Post: 28th March 2011, 05:46 PM
  4. engineering an sr20det ke70??
    By Nic19 in forum Technical - Questions
    Last Post: 4th April 2008, 03:34 PM
  5. Engineering AE86 Front Brakes - VIC
    By dorifto89 in forum Technical - Questions
    Last Post: 29th April 2007, 04:29 PM
