Results 1 to 5 of 5
Thread: Uprated clutch master cylinder
    Senior Member stixy's Avatar
    Queensland
    The mount
    Brisbane, Queensland, Australia, Australia
    Default Uprated clutch master cylinder
    Hi all,
    Turns out i have some putrid clutch in the engine package i got from japan, the motor and box were already together and Beau assured me that the clutch was fine and i didn't have to open them up, so i slapped it in.
    anyways as said this clutch is crazy heavy and i have about 20mm of travel in it before it throws my foot of the floor hahaha
    anyway i would like to change my master cylinder to cope with this and a friend from work suggested that a smaller master will make it that little bit easier to put down i.e less mass/fluid to move?
    anyway, anyone know of an uprated clutch master cyl for my KE70
    Thanks
    also have a bit of a rattle when clutch is engaged, could this be my throw out bearing?
    Jake
    Northgate
    Might work, I would say pretty much any master cylinder would fit but can't say for sure. Noise sounds like throw out bearing, goes away when clutch pedal is depressed? My landcrusier has a noisy one, but doesn't bother me enough to fix it, haha.
    Member rianwest's Avatar
    May 2010
    Rian
    Taringa
    Yeah you're right:
    Pressure = Force / Area
    which rearranged gives:
    Force = Pressure * Area
    (pressure remains constant throughout the system)
    So if you decrease the cross-sectional area of the master cylinder you will decrease the amount of force required to depress the clutch, however it will increase the amount of pedal travel required to displace the same amount of fluid as a larger master cylinder.
    Most master cylinders have the size marked on them don't they? So I guess you could just go around the wreckers checking master cylinder sizes until you find a smaller one that will fit. Either that or you could make the clutch pedal longer if there is room?
    Queensland
    The mount
    Quote Originally Posted by rianwest View Post
    Yeah you're right:
    HHMMM yeah might try that on he weekend.
    might try race industires and see what they say and have.
    Thanks for that rainwest
    Mt Macedon
    Other, probably more involved, options would be to move the pivot point of the clutch pedal, effectively increasing leverage on the master or getting your current master sleeved and a suitable smaller piston fitted.
    Either way a standard master with a smaller diameter would still be the easiest option.
  1. ae71 Clutch Master Cylinder
    By pauliee in forum Cars or Parts Wanted
    Last Post: 23rd October 2011, 08:45 AM
  2. AE86 Clutch pedal and master cylinder
    By 86TRD in forum Cars or Parts Wanted
    Last Post: 15th December 2009, 09:09 AM
  3. Sensor & Clutch Master Cylinder
    By Eircamae86 in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 07:00 PM
  4. WTB: Clutch Master Cylinder AE86
    By drif86s in forum Cars or Parts Wanted
    Last Post: 14th April 2007, 09:18 AM
  5. Clutch master cylinder thingy
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 13th December 2006, 11:50 AM
