Results 1 to 4 of 4
Thread: Wanted!! Ae86 4age fuel sender/pump
    Junior Member bapp88's Avatar
    mark
    nsw
    strathfield south
    australia/ireland
    Default Wanted!! Ae86 4age fuel sender/pump
    Want the full sender/pump assembly to drop into tank an go.. Any help would be great.
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    What exactly r u after
    EFI Pump setup and/or
    Fuel sender ? as two seperate items
    Have both available
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    mark
    nsw
    strathfield south
    australia/ireland
    I changed the 4ac engine in my adm ae86 too a 4age and I need the full efi setup. Want complete unit to just drop in and connect up.
    Craig
    Upper Caboolture
    Quote Originally Posted by bapp88 View Post
    Hi
    You will need to remove your tank and put the EFI JDM Pump setup into it in place of the old 4AC tank pickup. You will then need to run a positive wire to the front right hand side kick pannel and a earth to the rear beaver pannel where the lights earth out. You will also need to modify the fuel pump conection for the supply line as the JDM cars have a different threaded connection as a pposed to the ADM 4AC only have a slip on connection.
    Have the pump setup available in stock $ 200 delivered syd.
  1. Ae86 fuel sender
    By irl86 in forum Cars or Parts Wanted
    Last Post: 30th November 2012, 10:13 AM
  2. Ae86 adm fuel sender
    By [-not-agn-] in forum Technical - Questions
    Last Post: 4th December 2011, 12:23 PM
  3. Replies: 2
    Last Post: 5th April 2010, 06:54 PM
  4. Ae86 JDM Fuel Sender
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 31st March 2010, 01:16 PM
  5. JDM Fuel tank, fuel pump and sender wanted
    By Toyo86 in forum Cars or Parts Wanted
    Last Post: 9th August 2007, 10:10 AM
