Results 1 to 5 of 5
Thread: Newb Yankee!
    Jan 2013
    jarrod
    missouri
    st louis
    united states
    Default Newb Yankee!
    Hello,
    My name is Jarrod, reside in the US, and have had TERRIBLE luck with corollas.
    Current setup:
    !983 ke70 4 door
    86 rear suspension
    blacktop 20V
    megan coils
    other odds & ends
    First thing i need to search is upgrading the steering angle, gotta find some jdm tyte body pieces then hit every autocross/drift/track event i can!!
    Thanks for lettin me in!!
    Welcome...
    If you get stuck with specific questions post up in the techical area what you are after...
    Veteran Konakid's Avatar
    Henry
    Eastern
    get some AE86 power steering model steering arms. they will give you a nice amount of lock and faster steering, a very good mod to do.
    Jan 2013
    jarrod
    missouri
    st louis
    united states
    Thanks for the heads up!!
    Would i have to convert my knuckles? just bolt on and go? Should I keep stk application tie rods?
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    Standard everything will be fine, bolt in, go get wheel allignment and u turn like a pro
  1. NEED ADVICE, PRETTY NEWB
    By Gorgi in forum Technical - Questions
    Last Post: 8th January 2013, 10:57 PM
  2. Question from a yankee
    By Grant #2 in forum Technical - Questions
    Last Post: 1st May 2011, 01:59 AM
  3. another newb question
    By mtgg85 in forum Technical - Questions
    Last Post: 29th May 2008, 11:57 PM
  4. Clutch master, slave newb question
    Last Post: 5th May 2008, 06:02 PM
