Oh ok. Well it's an autech running stock ecu so you would imagine it will be fine?
I got oil and new filter today actually I got nulon 10-40 full syn
"All the current gasoline categories (including the obsolete SH), have placed limitations on the phosphorus content for certain SAE viscosity grades (the xW-20, xW-30) due to the chemical poisoning that phosphorus has on catalytic converters....
....Example; in API SG rated oils, this was at the 1200-1300 ppm level for zinc and phosphorus, where the current SM is under 600 ppm. This reduction in anti-wear chemicals in oil has caused premature failures of camshafts and other high pressure bearings in many older automobiles and has been blamed for pre-mature failure of the oil pump drive/cam position sensor gear that is meshed with camshaft gear in some modern engines."
Boom! Dump some molytec/liquimoly/comp cams cam break in additive in and have happy rockers/camshafts.
M1 5W-30 kills SR cams.
Lastly, fuck buying nulon, it doesn't even come in the cool coloured orange bottle with the gold metallic anymore. lol (ran nulon in SR before, bought it because it was cheap and the bottle looked cool.)
