Results 1 to 3 of 3
Thread: crunching when engaging gears - cause of?
    Member extra_anchovy's Avatar
    Nov 2010
    Damian
    Northgate
    Default crunching when engaging gears - cause of?
    my Celica GT4 (ST185) has been producing a slight crunch when changing gears (not 100% of the time but pretty often). it happens in gears 1-3 and especially in gear 3 and gear 1 sometimes produces a bit of resistance and need to somewhat force it in. it doesn't happen when changing gears when stationary. I had just had the gearbox changed not long ago, the previous one was crunching a lot before it just failed. when I bought it the dude said it had some weird 'competition clutch' and he said it's really sensitive. i was thinking maybe that has something to do with it, would changing to a normal clutch help things?
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    It wouldn't help things, I would suggest try changing to a better gear oil and if it doesn't improve the synchros are worn. Also worth checking is if the clutch actually disengages fully when you dpress the clutch pedal, because if it isn't the clutch will never be fully disconnected and wearing the synchros much faster.
    busted retainers on the clutch springs can also cause this...
  1. Clutch not engaging
    By wideslider in forum Technical - Questions
    Last Post: 4th December 2012, 01:09 PM
  2. speedo gears
    By JDM-086 in forum Technical - Questions
    Last Post: 1st November 2010, 03:34 PM
  3. 3tc T50 Clutch not engaging at right point
    By TrdHowie in forum Technical - Questions
    Last Post: 8th August 2010, 01:10 AM
  4. gears for t series
    By 1988whitey in forum Cars or Parts Wanted
    Last Post: 31st October 2009, 06:57 PM
  5. Clutch/gearbox crunching?
    By grape_moosha in forum Technical - Questions
    Last Post: 18th February 2008, 06:01 PM
