Results 1 to 3 of 3
Thread: 4AGE into KE70
    Jan 2013
    Glenn
    Carrum Downs
    Default 4AGE into KE70
    Hi all,
    New to the forum and new to 4AGE's. My son and I are putting together a KE 70 race car. He purchased in in bits as as a partly finished drift car we think. The engine is out of a FWD and I need the cooling bits and pieces for a RWD. I have the RWD water pump and alternator bracket. I did purchase the thermostat housing section but it's out of a FWD and is no good to us ( i think). I do need your expert assistance in advising us what parts I need and if anyone has them available for sale that would be fantastic. Looking forward to hearing from you guys.
    Cheers,
    Glenn
    Hey and welcome to the forum....
    Cheapest is to run the FWD cooling gear.... and fwd alternator bracket / setup... get the mounts off Jordo (ke conversions) and bolt it in onto the ke crossmember. Peddle box wise he can also mod your ke one to suit.
    Cut n shut the inlet manifold or buy one from either sc86 or justjdm, extractors best bang for buck are the universal ones kaizen garage sell as well.
    Rob
    Moorabbin
    Hi Glenn ,
    In my ke70 I just used the ae82 setup for alternator and water pump. I took the FWD remote thermostat housing and plumbed up the cooling system under the intake manifold. For a radiator fan I just run a thermofan.
    Is the engine a small port or bigport? For bigport a Jap spec ae86 rwd manifold is best, for smallport you have no choice except to cut and shut (or go 20V quads )
    I agree with what Matt said about the Kaizen garage exhaust, I had one a couple of years ago and it was good value for money.
    There will be various bits and bobs for the FWD motor, needs a spigot bearing at centre of flywheel, also it will have a hole in the timing cover case where the FWD engine mount went, a lot of people leave it open but I closed mine off.
    Depending on the transmission you use (JDM or ADM T50) you will need a clutch line to clear the exhaust. Also you have to put a clutch master cylinder mount on the firewall.
  1. KE70 4AGE Conversion Parts, KE70 Cage, Panel Van Front
    By Jacobxxx in forum Car Parts For Sale
    Last Post: 5th February 2013, 01:12 PM
  2. KE70 to 4age conversion parts and ke70 wagon wrecking
    By Sam-Q in forum Car Parts For Sale
    Last Post: 3rd August 2012, 09:41 AM
  3. Ke70 wiring diagram - help wiriing 4age into ke70
    By Low Style in forum Technical - Questions
    Last Post: 24th October 2010, 09:06 AM
  4. Replies: 5
    Last Post: 17th May 2010, 02:23 PM
  5. KE70 4AGE 20V $5000 my orange 20v slanty front ke70
    By sam007 in forum Cars for Sale (Toyota Only)
    Last Post: 7th April 2010, 09:26 AM
