Results 1 to 10 of 10
Thread: what is this?
    Jun 2011
    bazz
    nsw
    sydney
    Default what is this?
    hi all
    NOOB question as i know little about the 4age
    want to isntall and oil pressure sensor instead of oem sender
    im assuming its a 1/8bpst
    Also what is the bolt next to it?
    can it be used for oil temp?
    any idea of thread
    any help is much appreciated
    Jun 2011
    bazz
    nsw
    sydney
    Senior Member BLIPAE86's Avatar
    Daniel
    qld
    The Switch
    im pritty sure but maybe wrong that would have coolant behind that bolt
    Jun 2011
    bazz
    nsw
    sydney
    ahh fair enough. probably where u drain the coolant
    thanks champ
    Jun 2011
    bazz
    nsw
    sydney
    has anyone put a water temp sensor here? or is that too hot?
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    T piece for oil temp sensor onto where stock one goes.
    Just use an adapter in rad hose like everyone else does?
    Jun 2011
    bazz
    nsw
    sydney
    fair enough will go with the t peice, yeah have the rad hose adaptor but thats running the thermostat for the thermos
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    yes you an run a temp sensor there for coolant
    the one to the left of it is oil
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have been told that if you do run a T-peice then don't use brass as the vibrations can snap it off and that will destroy your engine. I can't see that happening to something out of steel though
    Alex
    Wagga Wagga
    Quote Originally Posted by Sam-Q View Post
    Yep, wrote about that in my build thread as I had that happen to me a year ago. It isn't so much the vibrations alone, but the vibrations combined with the weight of the pressure sender and switch hanging off the brass.
    I ran a single line from the block to a remotely mounted T-piece in the engine bay. No issues at all now
    Alex's 4AGTE KE70
    Or so was thought...
