Results 1 to 10 of 10
Thread: Itb's and some other goodies
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default Itb's and some other goodies
    Ok I'm doing a cleanup of some JDM shit I'll be adding more as I find it
    1. A set of blacktop itb's complete minus tps
    2. A set of silvertop itb's complete with tps
    3. TRD lead set for 4age 16v
    4.t50 gearbox
    5.t50 gearbox
    Prices
    1. 370 Ono
    2. 300 Ono
    3. 80 Ono
    4. sold
    5. 470 ono
    condition and details
    1. fully cleaned no corrosion ready to bolt on can block off all un used vacume ports for a clean look
    2. fully cleaned no corrosion ready to bolt on or use on a 16v can also block off all un used vacume ports
    3. clean and low resistance checked recently have been siting in a box
    4. a spare t50 i have laying around complete with shifter as is condition
    5. my current t50 jdm bell comes with c's short shifter has a brass shifter bush kit alone worth $200 out of japan has ae71 gearbox crossmember and sam-q spacer for 20v seals bearings and syncros in good shape has clutch fork and bearing with near new carrier there is alot of money in this box can be taken for a drive before taken out if bought soon
    Location is Sutherland shire Sydney nsw
    Contact through pm
    the dyno pull to 300rwkw
    Mathew
    Sutho Shire
    bump more parts added
    Senior Member JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    PM Sent
    Mathew
    Sutho Shire
    this is the blacktop throttles they are clean but still need am little bit more to be perfect
    Mathew
    Sutho Shire
    stock t50 sold
    Throttles look mint...how'd you clean them up?
    Sep 2010
    Daniel
    Sydney North
    Also Curious!
    Dec 2012
    aaron
    cecil hills
    check your inbox!
    Mathew
    Sutho Shire
    media blaster and alot of elbow greese cleaning all the grit out i still have to completely strip them and keep cleaning them they are almost done
    Mathew
    Sutho Shire
    bump
  1. silvertop itb,s
    By a222133 in forum Cars or Parts Wanted
    Last Post: 28th December 2012, 09:17 AM
  2. 16v Smallport w/ S/T ITB's
    By 08ftwyo in forum Technical - Questions
    Last Post: 20th May 2012, 10:22 PM
  3. ST ITB's + Smallport?
    By stahlz_ae86 in forum Technical - Questions
    Last Post: 15th July 2009, 11:28 PM
  4. turbo and itb?
    By 510lj in forum Technical - Questions
    Last Post: 19th June 2008, 11:47 PM
  5. ITB or CAMS??
    By DK86 in forum Technical - Questions
    Last Post: 30th July 2007, 11:18 PM
