Results 1 to 10 of 10
Thread: Fitting Alloy Radiator Help
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Default Fitting Alloy Radiator Help
    Hi I just bought an ASI Performance alloy radiator for my AE86 and have trouble fitting the bloody thing,
    when I place the rubber mounts in the bottom brackets it seems like the radiator is too close to the light brace panels and the to brackets come no where near.
    when I take out the rubbers it still fouls a little and comes close to fitting.
    Has anyone had this problem? Or know what to do?
    Sep 2012
    Tristan
    Koongal
    got a pic? from memory i had to cut some of the panel away (sadly) to make it fit and i also had to space the top two brackets up to hold onto the radiator
    Kaan
    Emerald
    will take some pics tomorrow dont really want to cut my engine bay as its all painted
    Aug 2010
    Geoff
    mt dandenong
    Sounds pretty shit, from what others have said I was under the impression of them being a direct fit. I'd be asking for a refund or get them to fix it. If its marketed as a replacement for a Ae86 rad it should just bolt in
    Veteran slide86's Avatar
    Huw
    Hills
    yep my rad did the exact same thing
    im going to get the mounts cut off the radiator and re welded further towards the front of the rad so it sits back slightly
    Kaan
    Emerald
    I've sent them a msg on eBay telling them what's goin on and no reply as yet
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    I think the same thing happened in my last car... I just bent the little brace panel a little. Worked fine after that
    Current Cars:
    Todd
    Cleveland
    I have fitted a few of these before. You need to trim the light panel about 2mm where it has a little protrusion. You also have to trim the front edge of the radiator on both sides. This is the same whether it be Koyo of cheaper radiators.
    Todd
    Veteran johl's Avatar
    Johl
    that is what i did^^^^ i think i just used an angle grinder to take a few mm off either side and it fit fine after that
    Kaan
    Emerald
    Yeah I think I'll do that too but I'm away for a week ill post a pic when I do it
  1. Godspeed alloy radiator. SA
    By McLEVIN in forum Car Parts For Sale
    Last Post: 23rd November 2012, 11:27 AM
  2. Alloy Radiator!
    By Drift_Donkey in forum Car Parts For Sale
    Last Post: 23rd August 2011, 07:24 AM
  3. Alloy Radiator
    By Low Style in forum Cars or Parts Wanted
    Last Post: 11th September 2009, 03:56 PM
  4. alloy radiator
    By fatke in forum Cars or Parts Wanted
    Last Post: 25th May 2009, 11:06 AM
  5. alloy aftermarket radiator for a AE86
    By silver styler in forum General Topics (No Technical Questions)
    Last Post: 20th May 2008, 02:13 PM
