Results 1 to 3 of 3
Thread: What gearbox and dif should i be running?
    Junior Member MuttAE86's Avatar
    Jan 2012
    beau
    Worrigee
    Default What gearbox and dif should i be running?
    Hey guy's, ive just had my 4agte rebuilt with piston rods cams etc, it should be putting out around 350rwhp when i get it tuned. I was wondering if i upgraded my t50 gearbox to a w58 would it still be strong enough? and i have a stock t series dif with a welded center what would be the best option for a upgrade? Cheers.
    Jake
    Northgate
    The W box should be pleanty, wou will probably want to run a F or G series, G series come up cheap and heaps of ratios but same for F series but don't seem to be as cheap when they do come up unless it's the one that is about 20-30mm a side wider, my hilux is only 10mm a side wider than a T series and cost me $250 to buy the diff and put mounts on it.
    Mt Macedon
    Box: W58 is a good option. W5* would probably do too. Could always go Hollinger if money is no object though.
    Diff: F series, G series, R31 are all options.
    This has been discussed to death on here and other places around the net. A search will turn up hours of enlightening reading, after which you can decide what is best for your car, your aims and your budget.
  • Similar Threads
    1. suitable gearbox/diff upgrades for ADM sprinter running 4AGE 20V???
      By schmykel in forum Technical - Questions
      Last Post: 20th July 2010, 11:40 PM
    2. FS: 4k motor and auto gearbox complete running Sydney,NSW
      By ghetto ke in forum Car Parts For Sale
      Last Post: 2nd July 2010, 02:54 AM
    3. dif info please
      By ke_70_blue in forum Technical - Questions
      Last Post: 3rd June 2010, 07:41 PM
    4. locking a dif
      By Haul in forum Technical - Questions
      Last Post: 19th July 2007, 08:07 PM
    5. TRD 4.6 Dif gears
      By Gilly in forum Car Parts For Sale
      Last Post: 4th March 2007, 02:17 PM
