Results 1 to 2 of 2
Thread: 4AGE big Port Genuine RWD Complete
    Junior Member DGLEVIN's Avatar
    Robertson, NSW
    Default 4AGE big Port Genuine RWD Complete
    4AGE - 16v Motor - rebuilt 23k ago - Genuine RWD
    New Wade Cams - TRD copy.
    Recon - 16v Cylinder Head - New Head Bolts - Genuine Toyota Head Gasket
    GTS - fuel injectors - 220cc - std 182cc
    New oversize cast pistons - 81.5 mm
    New bottom end bearings
    New oil pump
    TRD ingition leads
    Alternator - Recond 12 Mths ago
    Starter Motor - Recond 12 Mths ago
    Excedy Uprated Pressure Plate and Clutch Plate
    New Flywheel Bolts
    Air Inlet Pod.
    Full Loom with Computer
    All water heater hoses
    Engine mounts
    This motor is complete, just drop it in, connect it up. Away you go.
    This motor pulls strong all the way to rev limit, does not run out of puff.
    With after market computer will produce 100 kw at the rear wheels
    $1650 - located in Sydney southern suburbs - will help with delivery in Sydney
    Call David 0404097401
    Robertson, NSW
    bump
  1. Replies: 0
    Last Post: 24th January 2011, 04:26 PM
  2. rwd small port 16v complete with rwd 4age harness sydney
    Last Post: 24th July 2010, 05:12 PM
  3. 4AGZE- Bottom End Complete, Big port Head, NEW RWD W/P
    By Hektic323 in forum Car Parts For Sale
    Last Post: 18th June 2009, 04:48 PM
  4. 4age head big port + rwd intake
    By coastal86 in forum Car Parts For Sale
    Last Post: 27th September 2008, 08:17 AM
  5. Replies: 2
    Last Post: 3rd January 2007, 08:52 AM
Tags for this Thread
