Hay mate ill take the ca mount kit and is the gearbox mount for a ca or rb?
i just sorted through all my shit and made a list of parts for sale. this is just a copy and paste from other websites. pm me for better prices
All parts located near ipswich QLD but can post at your expense.
pm me or leave a reply here
AE86 Specific items-
CA18 into AE86 engine and gearbox mounts
SOLD
Cusco front and rear swaybars with bushes
SOLD
Mint redlines tail lights
$400
AAE86 QLD personalised plates
$400
sr20 to ae86 clutch line
$50
bigport fuel rail with sard fpr and speedflow filter
$150
SOLD
ajps rose jointed adjustable lca's
SOLD
cusco 30mm rca's
SOLD
jdi shortened knuckles
SOLD
quaiffe quick rack with ajps adjustable tie rod ends. tie rod ends are brand new but the ball joints have perished. new super pro bushes
$450
wilwood front brake upgrade including hubs
SOLD
radiator swirl pot
$50
oil catch can. mounts where your wiper motor is
$80
3 inch stainless exhaust with flex pipe. mounted to low mount turbo gktech dump pipe. may require slight mods to fit your turbo depending on how your engine is mounted and what manifold you use
SOLD
lobster intercooler piping and new kn filter. used on my ca but it is not too different from 4a so may require slight modification to fit.
$350
cusco castor rod brace
$100
JIC gold front coilovers. i never used them but i bought them from a guy that said they were in good working order. they go super low
SOLD
NON AE86 SPECIFIC ITEMS-
super cheap creeper
$30
dry cell battery. brand new. paid $390
$275
switch panel
$20
surge tank setup
bosch 044 pump, 120L/h lift pump, 2 L surge tank, all new hoses, new 8mm line to run the length of the car to replace 6mm hard line. only thing you need is the 1/2inch line from surge tank to 044 pump
$275
tacho. i think its 5inch?
$50
bm44 brake master cylinder and r32 booster. bolt in upgrade. bought from jdm garage
SOLD
spirit wing
SOLD
3 inch cat from gktech
$150
hydro hand brake
$80
4age backing plate
$50
it is for ca box. the driver side mount mount is different to alot of other kits out there as you may see. that is because i run a hks oil filter thermostat and remote mount oil cooler. so the mount will clear almost any oil cooler kit out there which is a good thing
Ill take the castor rod brace...pm me your bank detailed please
Vener
Do the redlines have numberplate lights too?
no they dont have number plate lights. pretty sure ae82 ones fit inside though
parts that are sold pending payment-
-both boost gauges
-spirit wing
-fuel rail
-castor rod brace
-engine and gearbox mounts
Any idea how much the catch can holds?
I'm pretty keen and can pay for it ASAP
Cheers,
Andrew
i will fill it up with water tomorrow and get back to you
Hi interested in the gauges. Just wanted to know the size of them?
