Results 1 to 10 of 10
Thread: 4AGE 20v hesitates to rev beyond 2000
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    Default 4AGE 20v hesitates to rev beyond 2000 with video
    Car:AE86 Trueno Silver Top Block with MAP and BT ECU, individual coils
    Problem:Engine refuses to go beyond 2000rpm on all gears, it splutters, quads back fires and pretty much hesitates to rev.
    Done so far, checked for vacuum leaks
    Replaced TPS
    Replaced Fuel Filter and new fuel in tank,
    Unhooked the O2 sensor and did not make any difference.
    Checked plugs and coils
    Cheers, Vener
    Start by checking the alternator voltage and timing.
    Also let her warm up too
    Vener
    NT
    Lyons
    Thanks Matt, I'll check the alternator.
    Timing is ok....
    Cheers,
    Vener
    Vener
    NT
    Lyons
    I took a video using my Go Pro and see if it helps, on :41,:55,:59,1:05, with light throttle(30%) and shifting below 3000 rpm from ist to 5th.
    then on 1:30 shifted down to 2nd gear with full throttle and the flat spot can be felt before 3000 and after that it revs and makes power.
    here's the link: camera is located behind the driver side head light
    Video to be uploaded soon
    Mar 2011
    Ced
    Rowville
    Here's a couple of things I've encountered with my 20v, they might be worth checking on yours, since I had similar issues to you.
    Knock sensor (someone had screwed in a random knock sensor on my block, if this is the case, you will get an engine check light)
    Fuel Pressure Regulator (mine was stuffed, did not hold the correct pressure in the rail)
    Fuel Injectors (2 out of 4 were dead, had to get them flow tested, and replaced)
    VVT pulley (mine was defective, and needed replacing)
    Fuel Injectors are really easy to miss, as you can't get a diagnosis from the ecu. I've been fooled twice on two seperate engines looking for the root cause elsewhere.
    Steve
    around 2000rpm is where the stock ecu fires up the VVT (might be a fraction less), you have timing or vvt issues with back fire thru the quads.
    Although im lead to believe when the vvt plays up or is broken it can make a terrible rattle.
    Any error codes on the ecu?
    So your only effected between 2000-3000rpm?
    Vener
    NT
    Lyons
    here's the video
    Site Supporter
    Nov 2012
    Tony
    Without vvt it would struggle up top....
    Veteran slide86's Avatar
    Huw
    Hills
    how do you have the individual throttles wired with the stock ecu???
    backfiring through the intake and no revving is engine timing.......sounds like the timing is WAY out. Either mechanically or something is really advancing the timing cause early ignition.
    i know you said the timing was ok.......but from the sound of the fault it doesnt seem so
    Steve
    Incorrect.
    VVT is there to aid lower rpm torque and power, its turns off around 6-6500rpm from factory.
    Without VVT you have alot less low rpm power and torque till about 6000rpm then it evens back out again..
  1. Any advice, blacktop 20v 7age wont rev past 6500rpm
    By JinxD in forum Technical - Questions
    Last Post: 20th January 2013, 07:07 PM
  2. 20v unable to rev past 7k
    By H8CHIR6KU in forum Technical - Questions
    Last Post: 14th January 2010, 06:37 PM
  3. 20V idle and rev issue
    By fat20v in forum Technical - Questions
    Last Post: 4th August 2009, 12:06 AM
  4. 4AC hesitates when cold
    By li21 in forum Technical - Questions
    Last Post: 9th January 2008, 10:10 PM
  5. 20v rev limit
    By Bustin_86 in forum Technical - Questions
    Last Post: 7th July 2005, 12:31 PM
