Had a little drive of this the other day ,the pick up for such a big car is amazing (2jz) awesomenes . Idrove 1jz soarer at local hill climbs a few years ago and the aristo is twice as quick (hint hint #¥€£$ )
The towing performance of this motor needs to be experiencd to believe.....
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Sweet, You know how many Kg/mm your springs are? Also How do the brakes handle it?
Just another Muppet
The brakes have been upgraded to the 4 pots and bigger rotor. The brakes are amazing.... Pulls up quickly while towing no troubles with ZERO brake fade....
I actually dont know the spring rates yet...... Not really stiff tho, but much stiffer than factory of course... They are only TEIN Superstreets......
Sounds awesome, the only thing that worries me is I have heard a few times of towing with some vehicles like this is stretching the chassis with excess load causing read door jams etc to have bigger gaps
Yeah, I have heard this too, but never seen proof... But with just a bit of care and common sense when towing, it should be ok..... The way they have mounted the tow bar uses thick steel plates and chunky bolts....
Mostly on the chasers being all alloy chassis... jzx100/ 110 etc.
interesting...
DAY TRIP -
Canberra --> Richmond, NSW
Pickup Zed32
Richmond, NSW --> Canberra
From the difference in fuel consumption on the way there and back I'm not even sure the aristow knew the Zed had jumped on!
Current Cars:
