Results 1 to 2 of 2
Thread: AE86 PROJECT
    May 2011
    Shannon
    Default AE86 PROJECT
    For sale: ADM AE86 1985 “SIR86” PPQ Plates.(rolling shell)
    Location* Brisbane
    Asking Price: * $8500 ONO
    Killometer's: * 386,858 Chassis
    Condition: Body is in excellent condition, HAS NOT been involved in an accident, Body is clean and straight . Some small rust repairs are visible around the windscreen, rear beaver panel, roof and fuel filler which were carried out prior to my purchase I can confidently say there is NO RUST . Note it was rust proved from the dealership when new which might be the reason the doors and rest of car is quite clean. Whole car minus the engine bay has been resprayed gloss red ,which would benefit from a cut and polish
    Modifications:
    Engine bay has been Shaved and seem welded with relocated battery and fuse box, Then professionally resealed and painted in a high-gloss white which cost $2500
    Engine bay has had every nut and bolt replaced with either stainless or high tensile
    Cross member’s, mounts And brackets have been powder coated metallic grey
    Front strut casing’s have been powder coated black
    BRAKES
    FRONT:WILWOOD Big Brake Kit slotted/cross drilled rotors 4 pot calipers braided lines and racing pad’s
    REAR: Standard T-18 drums
    Reconditioned Brake Booster
    NEW 1” master cylinder
    Reconditioned distribution block
    Custom Braided&Teflon coated Brake lines to replace all hard lines
    SUSPENSION
    FRONT: Custom Coilover’s (Fully Adjustable)-TOKICO HTS101 shocks, Damper adjustable, Height adjustable, Spring rate adjustable
    8kg springs
    CUSCO adjustable camber tops
    CUSCO RCA’s 30mm
    Adjustable Castor Rods (rose jointed)
    KELWAY strut brace
    NEW inner & outer Tie Rod Ends
    Reconditioned steering rack also Powder coated
    Front Bushings replaced using PROTHANE
    REAR: KYB AGX shocks (Damper adjustable)
    6kg springs
    WHITELINE Adjustable Panhard Rod
    AJPS Strut Brace
    All rear bushings replaced using PROTHANE
    DRIVETRAIN
    T series rear end from T-18 with rear swaybar mounts from S series welded on.
    CUSCO MZ 1.5 way LSD with 4.3 ratio setup by Duncan @ Top Cog
    NEW Wheel bearings
    WHEELS: 4 x SSR Reverse Mesh 15x7 UNKNOWN OFFSET BALD TYRES
    EXTRAS
    KOYO alloy radiator with twin 12’’SPAL fans
    GREDDY sandwich plate-fits either 4age or sr20
    TRUST 16 row oil cooler with EARLS braided lines
    AEROQUIP -6 300psi fuel lines
    PROFLOW 100 micron high-flow fuel filter
    SPEEDFLOW fittings,
    BOSCH ext Fuel pump 058464070
    Alloy Surge tank 2lt
    Custom Engine mounts to suit sr20motor/ae86 crossmember
    NISMO engine and gearbox mounts to accommodate sr20
    Quarter panels, bonnet, bumper, dash, grill and all interior plastics and trims are included but not fitted
    NOT INCLUDED
    SEATS
    MOTOR
    GEARBOX
    TAILSHAFT
    Complianced/Engineered: Mod plated yes.
    CONTACT: 0434587090 OR 0413839680
    https://www.facebook.com/media/set/?...1&l=a836994d8b
    Aug 2010
    Geoff
    mt dandenong
    pics no work =(
  1. ae86 project
    By madi86 in forum Cars or Parts Wanted
    Last Post: 8th January 2009, 04:36 PM
  2. My Project AE86
    By 4A-GE Power in forum AE86 Owners Forums
    Last Post: 2nd October 2008, 08:13 AM
Tags for this Thread
