Results 1 to 5 of 5
Thread: how do you make a 3vz bellhousing work with a beams
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    Default how do you make a 3vz bellhousing work with a beams
    Does anyone know what starter motor flywheel combination you should use when putting a 3vz bellhousing on to a beams i dont want to buy a 3vz starter motor if its not going to work with the beams flywheel
    Glenn
    North Ringwood
    use the std beams 1 i might have 1 here .thats if you are using the 6speed
    Gavin
    kilmore
    Quote Originally Posted by Celica RA45 View Post
    i got some custom flywheel that was based off a beams one it takes a 225mm clutch but the 3vz used a 236mm clutch so i was thinking that the flywheel that i have will be too small in diameter for the 3vz starter motor
    User fantapants's Avatar
    Pat
    what gearbag are you planning on using????
    06/07/2011
    Gavin
    kilmore
    Quote Originally Posted by fantapants View Post
    running an r155 same as an r154 but the input sharft is shorter so it sits in the right spot
  1. 3VZ-FE into AE86.
    By slydar in forum Offtopic Discussions
    Last Post: 8th March 2012, 12:42 PM
  2. pics of a beams pattern box to make castings
    By Celica RA45 in forum Technical - Questions
    Last Post: 16th February 2012, 08:34 PM
  3. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  4. Pair Work Ewings and Set of Work meshies.
    By Hektic323 in forum Car Parts For Sale
    Last Post: 20th August 2009, 06:29 PM
  5. Paid work - PHP + MYSQL work
    By Nick in forum General Topics (No Technical Questions)
    Last Post: 4th December 2007, 11:40 PM
