Results 1 to 10 of 13
Thread: AE86 20v struggle to start
    Senior Member LEVIN86's Avatar
    Nam
    Westside
    Default AE86 20v struggle to start
    Car -Toyota AE86
    Motor / part in question - 7AGE 20v (silvertop head with 7A block) with an aftermarket WOLF 3D ECU
    problem - My car is struggling to start up. Ill turn the key and the car sounds very close to starting up. Its cranking away and the revs on the hand controller get to about 300-400rpms. My battery has been fully charged and is reading 12.5v. Spark Plugs have been changed and Fuel Filter has been changed. Oil levels are fine.
    occurs/started when (if applicable)- Started about a month ago out of no where. One afternoon I went to the car and it just didnt want to start. Next day i changed sparks and at first it didnt want to start. After a few more goes it started up and i drove it a few times around the block. Got it home and turned it off then started it up again fine. After that i changed the heater core and then went to start it up and the problem was there again.
    The cam timing seems to be all lined up. The car seems to be popping a little from the exhaust too when im trying to start it.
    Any help or has anyone had a similar problem.
    Thanks
    Nam
    Aug 2010
    Geoff
    mt dandenong
    Injectors are squirting? Fuel getting to the rail ok? Does it start if you use some "start ya bastard" down the quads?
    Senior Member spoon's Avatar
    Oatlands
    does it start ok with throttle party open?
    Nam
    Westside
    Nope doesnt start at all. Tried starting with throttle open and no good. Have thought of checking the Fuel Pressure Regulator...not too sure how what the PSI reading should be. Read it was suppose to be 2.7 bar but then I dont really know.
    Sep 2012
    Tristan
    Koongal
    [QUOTE=LEVIN86;912894]Car -Toyota AE86
    Have you found the problem yet??
    i have a similar problem with my 20v, it doesn't start anymore at all ( sounds like timing is out) but i haven't found my problem yet either
    i can suggest though to go over all your earthing points and check your basic stuff, fuel pressure ( you want at least 40psi / 2.5l per minute) if you got trumpets get someone to look down the trumpets with open wide throttle and crank - disconnect coils though and see what the spray pattern is like.
    i am currently waiting for someone to lend me a ecu to try out
    Twisty
    Nam
    Westside
    PROBLEM SOLVED!
    Well I went thru all that I could with seeing if the fuel pump was working, seeing if fuel was coming out of the return lines, checking for spark, changing sparks, testing spare coil pack, charging battery, jump starting, changing fuel filter...after all that I could not do anything else. So it was time to go off to my wizard of a mechanic. He was able to push start it and get it started but would not start up on its own from a stand still. After some of his own testing with another guy from Wolf (im running a wolf 3d) they found the problem.
    I have a Microtech ignition module and it had always emitted a little electrical interference. For some strange reason it was releasing a lot of it and was messing with the whole ignition sequence causing it to spark at the wrong time. So a small circuit board was made up and fused into the loom to eliminate any electrical interference. Car now starts up perfectly and drives great again.
    Dont know if this information is much help to anyone but thought it would be a good idea to put this case to an END!
    Mechanic: Bryan from Racetec in Dandenong
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Hmm, i have a 4agte with a microtech lt10s and x4 ignition system, and my car also has a little bit of trouble to start, i need to push the throttle to about halfway while starting to get it to kick over, but once there its fine and idles nicely. the x4 unit goes to the bosch ingitor packs i believe.
    do you think its a similar sort of deal here?? all i need is a little circuit thingy?
    hope i used all the correct terms and stuff here
    Nam
    Westside
    I couldn't answer that sorry. Maybe see if you can get it tested by someone who is very familiar with Microtech gear in you area. They should be able to test and see if it may be the issue. My mechanic is one of the main dealers of WOLF and he knows his stuff so im pretty happy to have found him.
    They used some equipment of their own and was able to find the problem straight away. Best of luck man
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    It kicks over fine when its warm, maybe idle air control valve might not have on or something
    Sep 2012
    Tristan
    Koongal
    Quote Originally Posted by LEVIN86 View Post
    PROBLEM SOLVED!
    thats something very handy to know!
  1. AE86 Beams won't start...
    By ONCHRG in forum Technical - Questions
    Last Post: 7th December 2011, 01:08 PM
  2. 20v-16v conversion, engine wont start
    By meadan in forum Technical - Questions
    Last Post: 5th July 2011, 06:34 PM
  3. 4AGE 20v Help! - won't start!
    By DAMO46 in forum Technical - Questions
    Last Post: 5th March 2010, 06:53 PM
  4. Maybe they should start importing ae86 like these
    By kravit in forum Offtopic Discussions
    Last Post: 11th August 2007, 03:34 PM
  5. AE86 Start signal
    By Granto in forum Technical - Questions
    Last Post: 4th August 2007, 07:13 PM
