Results 1 to 5 of 5
Thread: need some advice on installing 20v itbs on 16v 4age bigport
    Feb 2013
    simon
    wa
    queens park
    Default need some advice on installing 20v itbs on 16v 4age bigport
    ok guys im currently building my ae71 road/drift car i have a 16 valve b igport 4age which im fully rebuilding at the moment i want to run it on 20v throttle bodies just need some help on choosing my wiring harness? (bigport/smallport) and what else is involved i have seen this done on a ke70 before and he was also running the standard ecu can someone help me please ....will upload pics of the build soon :/ thanks
    Senior Member JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    You will need to run aftermarket Engine Management AFAIK - I have a few sets of AE111 20V Throttle Bodies for sale if you need some.
    It'll run on the stock ecu if you wire the tps in reverse. But to get the most outta it an aftermarket ecu is recommended.
    Could be worth going a 20v?
    Veteran Rice86's Avatar
    Richard
    Liverpool
    well if you haven't already bought the ITB setup, i have the T3 adopter for bigport + 20v ST ITBs and TPS + 70mm velocity stacks for sale, $700 posted to your door!! cheaper then chips and gravy
    dose
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    What ecu are you running?(bigport or smallport) what dissy do you have,
    jsut stay with what you had with the wiring harness
    this a for WTB thread?
  1. 16v bigport v 20v? Carbs v itb's?
    By BMXB in forum Technical - Questions
    Last Post: 17th August 2012, 08:23 AM
  2. Replies: 11
    Last Post: 12th February 2012, 03:57 PM
  3. 20V Quads to 16V Bigport > Induction / Plenum Box
    By GeeEss in forum Technical - Questions
    Last Post: 31st August 2011, 05:47 PM
  4. st itbs to 16v bigport whats needed
    By sideburns in forum Technical - Questions
    Last Post: 7th August 2010, 05:39 PM
  5. Installing a W58 into my AE86 - Any advice/info/tips???
    By Maxhag in forum Technical - Questions
    Last Post: 9th April 2008, 10:51 PM
Tags for this Thread
