Results 1 to 4 of 4
Thread: (QLD) AE86 PROJECT part out
    May 2011
    Shannon
    Post (QLD) AE86 PROJECT part out
    For sale: ADM AE86 1985 “SIR86” PPQ Plates.(rolling shell)
    Location* Brisbane
    Asking Price: * $8500 rolling with parts
    $2800 non rolling
    Killometer's: * 386,858 Chassis
    Condition: Body is in excellent condition, HAS NOT been involved in an accident, Body is clean and straight . Some small rust repairs are visible around the windscreen, rear beaver panel, roof and fuel filler which were carried out prior to my purchase I can confidently say there is NO RUST . Note it was rust proved from the dealership when new which might be the reason the doors and rest of car is quite clean. Whole car minus the engine bay has been resprayed gloss red ,which would benefit from a cut and polish
    Modifications:
    Engine bay has been Shaved and seem welded with relocated battery and fuse box, Then professionally resealed and painted in a high-gloss white
    Engine bay has had every nut and bolt replaced with either stainless or high tensile
    Cross member’s, mounts And brackets have been powder coated metallic grey
    Front strut casing’s have been powder coated black
    BRAKES
    FRONT:WILWOOD Big Brake Kit slotted/cross drilled rotors 4 pot calipers braided lines and racing pad’s $750
    REAR: Standard T-18 drums
    Reconditioned Brake Booster & NEW 1” master cylinder $200
    Reconditioned distribution block $80
    Custom Braided&Teflon coated Brake lines to replace all hard lines (engine bay&under body) $600
    SUSPENSION
    FRONT: Custom Coilover’s (Fully Adjustable)-TOKICO HTS101 shocks, Damper adjustable,
    Height adjustable, 8kg springs,CUSCO adjustable camber tops $1000
    CUSCO RCA’s 30mm $20
    Adjustable Castor Rods (rose jointed) $100
    KELWAY strut brace $50
    NEW inner & outer Tie Rod Ends (AJPS) $50
    Reconditioned steering Rack- Powder coated GREY $200
    Front Bushings replaced using PROTHANE
    REAR: KYB AGX shocks (Damper adjustable),6kg springs $300
    WHITELINE Adjustable Panhard Rod $100
    AJPS Strut Brace $50
    All rear bushings replaced using PROTHANE
    DRIVETRAIN
    T series diff housing from a T-18 with rear swaybar mounts from S series welded on with
    a CUSCO MZ 1.5 way LSD with 4.3 ratio setup by Duncan @ Top Cog $1500
    NEW Wheel bearings
    WHEELS: 4 x SSR Reverse Mesh 15x7 UNKNOWN OFFSET $500
    EXTRAS
    KOYO alloy radiator with twin 12’’SPAL fans $1000
    TRUST 16 row oil cooler with EARLS braided lines and a
    GREDDY sandwich plate-fits either 4age or sr20 $600
    AEROQUIP -6 300psi fuel lines
    PROFLOW fuel filter
    100 micron high-flow $90
    BOSCH ext Fuel pump 058464070 $70
    Alloy Surge tank 1.5 lt $150
    Custom Engine mounts to suit sr20motor/ standard ae86 crossmember $250
    NISMO engine and gearbox mounts to accommodate sr20 $250
    Quarter panels, bonnet, bumper , dash, grill and all interior plastics and trims are included but not fitted
    NOT INCLUDED
    SEATS
    MOTOR
    GEARBOX
    TAILSHAFT
    Complianced/Engineered: Mod plated yes.
    CONTACT: 0434587090 OR 0413839680
ID:	28258Click image for larger version.
ID:	28259Click image for larger version.
ID:	28260Click image for larger version.
ID:	28261Click image for larger version.
ID:	28262Click image for larger version.
ID:	28263Click image for larger version.
ID:	28264Click image for larger version.
ID:	28265Click image for larger version.
ID:	28266Click image for larger version.
ID:	28267Click image for larger version.
ID:	28268Click image for larger version.
ID:	28269Click image for larger version.
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Will take the RCA's, pm'd.
    Cheers.
    SuperFunHappySliders
    SR's are ghey.
    Member gaspal's Avatar
    Richard
    Osborne Park
    Any more details on the castor rods? brand? how old? PM me if u want
    Member jaqule's Avatar
    Beau
    GoldCoast
    Fuel tank ?
    - "They're polyurethane sex toys Joe, they're not capable of Judgement"
  1. QLD ke70 project, 4agze
    By haveaparty in forum Cars for Sale (Toyota Only)
    Last Post: 24th February 2011, 09:13 AM
  2. QLD - AE86 unfinsihed project
    By mrmatt in forum Cars for Sale (Toyota Only)
    Last Post: 11th January 2011, 11:05 PM
  3. QLD ae86 20v project
    Last Post: 20th December 2010, 08:53 AM
  4. QLD EOI ADM Ae86 Project
    By Low Style in forum Cars for Sale (Toyota Only)
    Last Post: 19th January 2010, 02:07 PM
  5. AE86 part out QLD
    By biggo in forum Car Parts For Sale
    Last Post: 28th May 2009, 08:13 AM
