Results 1 to 6 of 6
Thread: WTD: 4AGE 20v ST intake cam, cap plate, crankshaft timing pulley
    Apr 2010
    Dana
    Qld
    Ipswich
    Default WTD: 4AGE 20v ST intake cam, cap plate, crankshaft timing pulley
    Hey guys,
    Im chasing an intake cam in good condition with little wear to replace mine that has a scored journal, and I also need the lower bearing cap plate that bolts to the head under the cam to go with. Will take a pair of cams if I have to and maybe even a dead head if the cams are good and the price is ok. Prefer Brisbane for these bits as the cam's a bit heavy to post.
    Also after a crankshaft timing pulley to replace mine that was accidentally damaged pulling it off. FOUND
    Really want to get cracking on this engine rebuild and get the car going (again) so help a chick out!
    Cheers,
    Dana
    Senior Member pt_y2k's Avatar
    Paul
    Have a crankshaft pulley here $80,located in logan. 0416 821 079
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have a pair of cams here for $30, pulleys extra.
    $20 for that bearing cradle
    Postage shouldn't be too bad.
    Be careful changing those bearing caps as you probably meant to remachine them after changing.
    That cooling kit still working for you?
  • #4
    Apr 2010
    Dana
    Qld
    Ipswich
    pt_y2k: just want to check its the timing belt pulley you have? Not the water pump/alternator belt pulley thanks.
    Sam, cams sound good, I'll talk to you about them over email since there's the other stuff I need off you
  • #5
    Paul
    Have both...
  • #6
    Apr 2010
    Dana
    Qld
    Ipswich
    All good, just found out you can still get the timing gear new from Toyota for $40.50. Thanks anyway.
  • Similar Threads
    1. WTB: 20V ST Dizzy (Can be minus Rotor/Cap) [BNE]
      By Oly AE86 in forum Cars or Parts Wanted
      Last Post: 7th November 2009, 06:30 PM
    2. 4AGE Crankshaft Pulley
      By DGLEVIN in forum Cars or Parts Wanted
      Last Post: 2nd October 2009, 10:23 PM
    3. WTD 20v timing belt crank pulley
      By 99Westy in forum Cars or Parts Wanted
      Last Post: 9th August 2009, 09:01 PM
    4. wtd: 4age Crankshaft!.
      By stanzzza in forum Cars or Parts Wanted
      Last Post: 10th April 2009, 02:37 AM
    5. Crankshaft timing pulley for 20V
      By charlie_keto in forum Technical - Questions
      Last Post: 13th May 2008, 09:24 PM
