Results 1 to 7 of 7
Thread: TPS plug
    Member Dskew3's Avatar
    Feb 2013
    dustin
    Palmwoods
    Default TPS plug
    i am doing a 4age bigport conversion into a adm AE86. i was doing the wiring tried to connect the plug to the tps but the plug on the wiring harness wont fit i need either a plug that will fit or a tps that will fit. i need one these ASAP.
    this is the sensor on the car
    pic 1>> Attachment 28154
    this is the plug on the loom
    pic 2 >>Attachment 28155
    Member rianwest's Avatar
    May 2010
    Rian
    Taringa
    Pics don't seem to work?
    Anyway, you can order both types of bigport 4AGE throttle position sensor and throttle position sensor loom plugs through Supercheap Auto. The plugs are cheap but the sensors are pretty expensive.
    Feb 2013
    dustin
    Palmwoods
    Ok I will try them thanks mate
    Aug 2010
    Geoff
    mt dandenong
    just grab a tps and plug off an old hyundai or proton. same same. go down to a wrecker and check it out. im sure the super cheap option is probably the same shit
    Feb 2013
    dustin
    Palmwoods
    I tried supershit nothing so iam gonna make a plug can't be to hard
    Veteran stahlz_ae86's Avatar
    Paul
    I can't see the pics, they aren't working for me. If you have a small port one I will happily swap for my big port one.
    Feb 2013
    dustin
    Palmwoods
    I got a mate havin a look at it 2morro so I will let yas no
  1. WANTED: 20V TPS Plug
    By klusio in forum Cars or Parts Wanted
    Last Post: 20th February 2012, 12:12 AM
  2. wtb: ae101 20v tps plug and ae92 4agze CAS plug
    By 84ae86coupe in forum Cars or Parts Wanted
    Last Post: 26th September 2008, 05:24 PM
  3. tps wiring plug
    By roger roger in forum Technical - Questions
    Last Post: 14th June 2008, 11:18 AM
  4. TPS plug
    By chapl in forum Cars or Parts Wanted
    Last Post: 15th August 2007, 03:38 PM
  5. tps plug
    By brad in forum Technical - Questions
    Last Post: 1st November 2006, 10:16 PM
