Results 1 to 10 of 19
Thread: Cat converter blowing out its insides.
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    Default Cat converter blowing out its insides.
    I don't know how to put this but today when I was playing with wires to find the wire that is causing my car to run badly something weird happened
    Anyways after a lot of starting and stopping over a couple of days and the car failing to start half the time I got the wires in a position where the car would run fine and have it a rev and "bang" half the innards off the cat blew out the back every where. It's only a new cat done about 150km, does anyone know what may have caused this ?? I've had a look about and found a few mixed answers.
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    When i had new high flow cats fitted to my "other" car the exhaust shop told me to not flog it for a couple hundred k's to heat cycle the cats as the metallic ones have to harden.
    I dont know if it was bullshit or not though.
    Excess fuel can apparently stuff them as well, they get to hot.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    running issues getting MAD hot from running really rich, cheap CAT???
    its done half your job for you anyways bash the rest out
    Jul 2012
    Wagga Wagga
    Right well there may be the problem it has been running very rich whilst playing up so that will have caused it then I think.
    other then being illegal which I don't care about is there any other problems it may cause like not getting enough back pressure etc and will I have to make sure I clear the rest out or just let it come out itself ?
    It's weird too the car seems slightly quieter now haha which is good as I need to add another muffler anyways.
    Jul 2012
    Wagga Wagga
    The cat was a $100 high flow eBay job
    Lindsay
    Mackay
    A car needing back pressure is a myth.
    Its probably quieter now because the cat is blocked, I'd gut it when you have a chance because its fucked anyway.
    Michael
    Crimebrook 2749
    its not pressure, its all about gas speeds
    Jul 2012
    Wagga Wagga
    Gayyyyyyy I have no flange there so ill have to cut it out to knock the rest out haha Owell the exhaust needs attention anyways I wanna tuck it up a little higher and add another muffler.
    Cheers for the info guys, its been really helpful.
    Jul 2012
    Wagga Wagga
    I was gunna ask too man I'm adding another muffler and a mate gave me a 2.25" and I have a full 2.5" exhaust will the 2.25 at the back restrict it all all?
    Michael
    Crimebrook 2749
    put it at the back
  1. cat converter question.
    By steroidchickens in forum Technical - Questions
    Last Post: 2nd October 2009, 10:30 AM
  2. 3inch cat converter
    By Fozz in forum Cars or Parts Wanted
    Last Post: 9th February 2009, 03:05 PM
  3. cat converter
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd March 2008, 10:05 PM
  4. WTB 3inch cat converter
    By reecegze in forum Cars or Parts Wanted
    Last Post: 12th February 2008, 12:26 AM
  5. cat converter
    By deleta in forum Cars or Parts Wanted
    Last Post: 11th March 2007, 06:16 PM
