Results 1 to 10 of 11
Thread: Ke70 panel van
    Member Anthony13's Avatar
    Jun 2012
    Anthony
    Yarra glen
    Default Ke70 panel van
    Heh ya I'm looking into getting my self another corolla and I'm heading towards a panel van this time and I've seen a few with the rear panels removed and replaced with glass does anyone now how this is done? Is the a build thread somewhere where someone has done this I'm interested very interested!! Click image for larger version.
    Mar 2011
    Ali
    Don't think full glass was Aus spec, only had very rear small glass, looks poxy, but check out haveaparty build thread and hit him up, I think he bought the glass off NZ trademe site and shipped it over. http://www.ae86drivingclub.com.au/fo...20c-powered-E7
    Jun 2012
    Anthony
    Yarra glen
    Yeah sweet thanks man I was watching this build at the start but haven't had a look at it for a while so ill check it out later on tonight an f20c ke70 would be insane!!
    Veteran stahlz_ae86's Avatar
    Paul
    We only ever got them fully panelled (like mine) in Aus. Any of the small shitty windows you see are normally cut in and I would assume it's for visibility while driving. If you get onto trademe.co.nz and create an account you may be able to find a listing with all the bits when someone wrecks a car, next step is convincing said Kiwi to safely pack up the glass and send it with the hinges and stays for the pop out. Our local 4 door wagon rear windows should fit I would assume. Check out Starni-boy's old build thread, he did it on his pano.
    Jake
    Northgate
    Should just make some perspex windows.
    Jun 2012
    Anthony
    Yarra glen
    Well I found some glass on eBay it says its for a ke70 wagon so Id think that'd work? And are the front guards on a panel van different than a flat fronted ke70 sedan the indicators on the front corners look to be bigger on the panel vans is this correct? Cos if I got a panel van I'd want to put in a set of quad lights so I wanted to no if they'd fit Click image for larger version.
ID:	28184Click image for larger version.
    Paul
    The blue early front car you posted the photo of will accept the quad headlights. Panelvan guards are different. Ke70 and ae71 panel vans both have same rad support as slanty front ke/ae71.
    Paul
    If the wagon glass on eBay is the rear two then I'd say it will fit. Quad headlights on to panel van rad support will require new holes to be drilled.
    Jun 2012
    Anthony
    Yarra glen
    I see so when you say drill more holes is that the only modification you need to make to make the quad lights fit a ke70 slant and panel van front?
    Paul
    And use all the panels from an early front ke70. Guards, bonnet & beaver panel.
  1. my ke70 panel van
    By akasod in forum KE70 / AE71 Owners Forums
    Last Post: 1st January 2014, 08:50 AM
  2. KE70 Panel van or wagon
    By KePanelVan in forum Cars or Parts Wanted
    Last Post: 25th June 2012, 11:13 AM
  3. MoNsTaR's Panel Van vanvan van van vanvanvan van
    By MoNsTaR in forum KE70 / AE71 Owners Forums
    Last Post: 15th December 2011, 08:48 PM
  4. ke70 panel van
    By dehney in forum Cars or Parts Wanted
    Last Post: 5th December 2011, 03:27 PM
  5. ke70 PANEL VAN
    By todd in forum Cars for Sale (Toyota Only)
    Last Post: 20th July 2008, 05:28 PM
