Radiator and exhaust pleeease! Double forum stalking lol
In SE me lbs, can pickup asap!
EDIT: ALL PARTS NOW GONE
All items in Melbourne Box Hill
Pickup preferred but will post at buyers expense
PM me here to discuss
Make a reasonable offer
EDIT: The following parts are now free to whoever picks them up this week, after this week they will be gone for scrap metal or something
AE86 S-series diff - drum to drum including sway-bar and tailshaft rear section $80 >> FREE
KE70 Full aircon setup $200 >> $50 >> FREE
- worked great when I pulled it out of the car
- includes compressor, condenser/dryer, cooler, piping, bracket for 4KC engine
KE70 FR Struts, brakes, LCA, Steering tie rod FREE
FOR SALE
19mm Rear swaybar setup including new superpro bushes (D bush and link bush), custom links and body mounts
To suit KE70/AE71/AE86 - Never been used, only trial fitted to my car. $60
Quad carb setup (SU type) for Honda CBR600 make an offer:
Ae82 4age oil cooler sandwich plate SOLD
Ae86 driver seat ADM SOLD
T50 shift lever, needs bushes replaced sold
AE86 Whiteline taillights SOLD
Bride fixed back Seat + AE86 rail - SOLD (seat fabric torn some places but ok, very functional seat, but not a looker)
AE86 T-series axles (pair) SOLD
- for disc brake (comes with large bearing), drum requires the bearing to be changed
- Zenki ('83-'85)
Momo leather steering wheel SOLD
Trueno Front seat set (Driver + Passenger) - SOLD
AE86 Coupe Full bolt in roll cage (6 points) -SOLD
T-series diff center, welded, 3.9 ratio. Gone
FREE STUFF:
Pickup only
STILL AVAILABLE:
Ra40 FR shocks, Monroe - fine condition, good gas pressure.
KE70 Drive Shaft (for auto)
KE70 Engine cross member with steering rack
KE70 Pedal box (for auto)
AE71/AE86 Clutch master cylinder + booster
XT130 steering arms (steering knuckle only, not LCA, maybe good for cut and shut)
AE82 4age rear engine cover (plate between gearbox and engine)
GONE:
4KC from a KE70
KE70 Auto tranny
KE70 Full exhaust
KE70 Radiator
KE70 washer bottle & pump
KE70 starter motor
KE70 coil & resistor
KE70 master cylinder & booster
KE70 Borgwarner diff & axle
- works just fine
- has brakesKE70 Borgwarner diff & axle
- works just fine
- has brakes
Might have other KE stuff left over from my conversion, feel free to ask. No bodywork or interior parts available.
pm'd re: bride seat, also need a ke70 washer bottle
List updated, sorry hingwah the rad and exhaust are gone (the guy who picked it up pm'd me first)
Seat on hold for Geoff, washer bottle gone though sorry.
Interested in the cage. Any idea if its cams approved? Do you have any pics of it installed? Also what condition are the tail lights in? Pics of faults?
Finally where exactly are you located? I live near hastings but work in Cheltenham...
Located in Box Hill and I work in Clayton.
Tail lights are in very good condition, I'll get some pics.
Cage is not cams approved (not sure if it meets the requirements or not but you may be able to get it approved)
Some pics of the cage installed.
Lights
This is the only defect I could find. Small scuff mark, would probably buff to be smooth and invisible.
It's on the bottom so not that noticable
Steering wheel
Cool. Any chance you can take the steering wheel and lights with you to work in the next day or 2 so I can drop by and have a look after you finish?
Also any idea what the cage is made of?
I just realised also that it's for a coupe.. will it work in a hatch?
Sure I can do that will PM you to organise things.
Not sure if the cage will fit in a hatch as I have never seen it fitted to one.. However where it mounts seems fairly similar between hatch and coupe so there is a good chance it will fit.
Updated,
make an offer... want this stuff gone
