Results 1 to 6 of 6
Thread: AE86 struts complete, Kouki LSD, 4x XT130 lca's.
    Nov 2010
    Peter
    Vic
    Northern suburbs
    Default AE86 struts complete, Kouki LSD, 4x XT130 lca's.
    AE86 struts complete with slotted adm solid disks, adm calipers, hubs, super low king springs, Gabriel gas inserts.
    Will not separate hubs/brakes so don't bother asking, $400.
    Kouki T series LSD with 4.3:1 gear set, came out of a housing with a broken axle and lots of broken metal pieces inside. Diff requires rebuild before use, as I had to release the pinion gear to get it to rotate for removal, $275.
    2 pairs XT130 lca's, 1 is bent, another has a flogged out ball joint hole(ball joint spins in arm) 1 pair of good nolathane bushes, $100 lot?
    Contact Peter via pm. Pickup only, pickup only, pickup only from Yallambie, Melbourne northern suburbs.
    Nov 2010
    Peter
    Vic
    Northern suburbs
    Bump
    Nov 2010
    Peter
    Vic
    Northern suburbs
    All still here, to the top!!
  • #4
    Mar 2013
    Jesse
    Queensland
    Mudgeeraba
    Hi mate do you think the diff will be fine if rebuilt? No cracks or chips? How much do you think a rebuild would cost and where abouts would you get it done or can you do it yourself? I have a Ta22 running a T50 and T series diff. Will this bolt straight in? cheers
  • #5
    Veteran stahlz_ae86's Avatar
    Paul
    TA22 diffs have zenki axle.
  • #6
    Nov 2010
    Peter
    Vic
    Northern suburbs
    Struts sold, diff and lca's still here. Diff is to suit late model large axle AE86. Will not fit TA22 axle.
  • Similar Threads
    1. Replies: 18
      Last Post: 5th December 2011, 11:48 PM
    2. WTB S.A: AE86 front struts, and Xt130 lca's
      By KE - LXX in forum Cars or Parts Wanted
      Last Post: 20th May 2010, 05:49 PM
    3. 14 x 7's, xt130 LCA, AE86 Struts, AE86 LCA [BRIS]
      By blair in forum Car Parts For Sale
      Last Post: 3rd November 2009, 06:52 PM
    4. removing LCA from XT130 struts
      By darkon in forum Technical - Questions
      Last Post: 27th January 2009, 05:16 PM
    5. will xt130 LCA's fit in a ke70 with the stock struts??
      By mtgg85 in forum Technical - Questions
      Last Post: 7th July 2008, 12:49 AM
