Results 1 to 3 of 3
Thread: Oil Pressure Sender - Wiring Diagram Question?
    Mar 2011
    Ali
    Default Oil Pressure Sender - Wiring Diagram Question?
    Morning,
    I am installing some gauges, one of which is oil press with one of these senders
    Now came with this diagram
    G is signal wire to gauge.
    WK is warning light/buzzer.
    This much is straight forward.
    Now there is also a green wire that comes from gauge...I'm looking at the diagram thinking it is telling me to attach/soldier green wire to the body of the sender?
    WTF, seriously, am I potato retard or is this correct?
    So I take it it earths through the body of the sender, but can't I just earth that wire to any common -ve?
    You're over thnking it... attach the green wire to the top knob.
    You'll find the guage also needs ignition power too of some sort and most likely a light too.
    Mar 2011
    Ali
    Yeah, I tend to do that.
    I just think that wiring diagram needs to be a bit more accurate...I mean FFS why draw it like that?
    I have power and parker illumination sorted.
    Gauge has low oil pressure light on it, I understand it now, thanks Matt!
  1. 4AG oil pressure sender
    By nelpd96| in forum Cars or Parts Wanted
    Last Post: 15th April 2010, 07:03 AM
  2. oil pressure sender questions
    By Fozz in forum Technical - Questions
    Last Post: 11th May 2009, 10:43 PM
  3. oil pressure sender
    By h1_roll4 in forum Cars or Parts Wanted
    Last Post: 14th August 2008, 08:21 PM
  4. URGENT: Oil Pressure sender??
    By LeviNafey in forum Technical - Questions
    Last Post: 3rd February 2007, 10:48 PM
  5. oil pressure sender unit
    By AE86dori in forum Technical - Questions
    Last Post: 14th August 2006, 06:47 PM
