Results 1 to 3 of 3
Thread: 4agze bolts specs
    Sep 2010
    dan
    vic
    Sunbury
    austraila
    Default 4agze bolts specs
    Hey does anyone know where I can get nuts and bolt specs for every part of a 4agze engine. Cause don't have nuts and bolts for it. Need specs so I can go to bolt shop an get some. Hope someone can help. Thanks
    Moderator Sam-Q's Avatar
    Endeavour Hills
    this is not likely to be answered as there isn't like a listing or anything. All the bolts are as follows
    6mm standard pitch (1mm)
    8mm standard pitch (1.25)
    from M10 and upwards they all have a 1.25mm pitch which is not a standard coarse pitch. From here measure everything up with a digital caliper for maximum length and deduct 5mm.
    Mt Macedon
    Given the non-standard thread pitch and/or head size they can be tricky to find at bolt places. Personally I'd go and strip a 4AGE (or any Toyota engine) at Pick-a-part or similar. That should give you most, if not all, of what you need.
  1. SA 4AGZE conrods balanced,re bushed and arp bolts
    By cracker in forum Car Parts For Sale
    Last Post: 29th September 2012, 08:09 PM
  2. 4agze Rods, Arp Bolts - Tasmania - Will Post
    By Skid_KE70 in forum Car Parts For Sale
    Last Post: 8th March 2011, 11:08 AM
  3. Rosejointed 4 Links, ARP Bolts, 4AGZE Rods, TAS
    Last Post: 10th August 2010, 01:55 PM
  4. Specs
    By benbertucci in forum Technical - Questions
    Last Post: 24th June 2009, 03:43 PM
  5. What are the specs on std 4agze cams?
    By Dongaz in forum Technical - Questions
    Last Post: 31st March 2008, 09:22 PM
