Results 1 to 1 of 1
Thread: [SA] 1JZ + all bits required for a swap! 1500 neg
    Mar 2011
    Ryan
    South Australia
    Mount Barker
    Default [SA] 1JZ + all bits required for a swap! 1200 BEFORE WEEKEND
    Hi.
    Bought this for a silly conversion, ended up having to sell the project off as I put a deposit down on a new car & need the space. So motor and stuff is up for grabs.
    For $1500, what you will get is:
    -14x,xxxkm 1JZ motor, turbos, alloy turbo piping, pumps, etc etc etc (timing belt done at roughly 102,xxxkm)
    -Rear main seal just done using genuine toyota parts + toyota gasket maker (at fifty friggin dollars a tube). Have reciepts for parts.
    -mid-rear sump as per JZZ30 config
    -factory alloy engine block mounts
    -auto transmission
    -auto xmember
    -full engine loom
    -full JZZ30 engine-bay loom w/ fusebox etc
    -ECU
    -Fuel pump ECU
    -dump pipe
    -some random other bits lying around
    For another $100, will install a front sump instead of the JZZ30 sump.
    So all you'll need to do, to put it in whatever your heart desires, is wire the motor up, make your own mounts, stick an FMIC on, and go play.
    I have an engine crane, so am happy to lift it into your trailer/ute/etc. Will throw in some old scrap tires for it to rest on in the tray.
    Price is negotiable. I do want it gone and if you pick it up very soon I'll be more lenient on neg.
    Cheers, contact if interested at all (or even in major parts like engine or box alone) by posting here, PM or 0422 056 272
    IF you pay for it before this weekend I'll be much more neg. Am happy for you to come do a comp test, and can organize interstate shipping on a pallet with courier or something.
  1. Replies: 1
    Last Post: 23rd June 2012, 01:50 PM
  2. SA - wanted ke70/ae71 - 1500 cash NOW !!!!
    By ke70kid86 in forum Cars or Parts Wanted
    Last Post: 14th May 2011, 12:13 PM
  3. F/s or swap: 94 cr250, qld $1900 neg
    By GHETTOKE70 in forum Other Items for Sale
    Last Post: 18th January 2011, 11:59 PM
  4. 1JZ GTE coilpacks x6 $250 or swap for rb igniter + $100
    By dr1ft-pig in forum Car Parts For Sale
    Last Post: 17th December 2009, 07:02 PM
