Street Road Track Disc Brake Pads
Work ‘em hot & hard!
If you’re after consistent braking power from first stop ‘til last, fade resistance when the heat’s on, and stopping power that responds to your driving style, then Bendix Street Road Track brake pads are the optimal choice.
Developed for Serious Performance Cars and Drivers
Bendix Street Road Track brake pads have been designed with the sports and performance car enthusiast in mind. These pads have been developed and comprehensively tested by leading friction engineers to create a pad designed to withstand a variety of uses – street, road and track. These pads have been rigorously tested against other leading brands under the most torturous conditions, so Bendix Street Road Track deliver superior control, high tolerance, low fade, long wear and high friction in all kinds of conditions. The rear of the pad also features a gasket to reduce noise and increase heat resistance.
Street Road Track adjusts to your driving style, so you don’t have to adjust to the style of your brakes. They give you confidence to handle busy, unpredictable driving on the STREET, where conditions can change suddenly. They’re reliable in demanding conditions, such as negotiating mountain roads with your foot constantly pressing on the brake pedal, or in cool running conditions such as cruising the open ROAD, where there are long intervals between braking. And assurance that your brakes will keep delivering lap after lap of hot, hard, last second braking on the TRACK.
ADVANCED SHIM TECHNOLOGY
SRT SHIMS FEATURE A UNIQUE NITRILE RUBBER COATING FOR REDUCED NOISE AND VIBRATION DAMPENING FOR QUIETER PERFORMANCE BRAKING.
This innovative technology features a thin layer of Nitrile Rubber on both sides of the Carbon Steel shim, providing a greater level of friction for improved stopping performance, and smoother, quieter braking.
Bendix SRT’s unique rubber to metal composite materials have been engineered for noise damping in disc brakes and combine a number of valuable properties: vibration insulation, compressibility and excellent adhesion. The Nitrile Rubber composite is excellent for applications with demanding insulation for vibration and noise. It also retains its integrity even when subjected to high pressure and high temperature, meaning you can brake harder, for longer. Shims / gasket available on most SRT part numbers.
For more information,
Or visit
