Results 1 to 5 of 5
Thread: Rear Sleeve Coilovers
    Mar 2011
    Tony
    St Albans
    AU
    Default Rear Sleeve Coilovers
    Hey Guys,
    When I adjusted the coilover for a roadworthy it was initially slapped on its arse at full settings. Now I can't even drop it so the tyre just tucks under the guard.
    The left hand rear coilover sleeve sits in on an angle.
    On the opposite side, they are straight up and down, but it is not on the left hand side.
    I am losing it wondering what's wrong with it, and need help.
    Thanks Guys
    Tony
    Senior Member davidgarratt's Avatar
    david
    morayfield
    Should be dumped in the weeds with no spring or bump stops
    自動車変質者 - Just about sums me up!!!
    Mar 2011
    Tony
    St Albans
    AU
    LOL it should, but i won't do that until i find out why its on an angle like that.
    Rob
    Moorabbin
    Need an adjustable panhard rod?
    That doesn't explain what changed since the last time you had it adjusted though...
    Mar 2011
    Tony
    St Albans
    AU
    I got an adjustable panhard rod.
    I should've said above, that I took it apart cause I found the spring was inserted the wrong way around. When I went to rectify the problem, the adjustment issue had occured. Then I noticed that it the bump stop was in on an angle. Does anybody know if their 86 is angled like this as well?
  1. Rear coilovers
    By GOODY in forum Cars or Parts Wanted
    Last Post: 30th May 2011, 11:36 PM
  2. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  3. does anyone want rear coilovers
    By scott_22 in forum General Topics (No Technical Questions)
    Last Post: 2nd August 2009, 01:44 PM
  4. rear coilovers
    By 350hp4agte in forum Technical - Questions
    Last Post: 21st November 2007, 03:49 PM
  5. Rear coilovers
    By 4000gt in forum Cars or Parts Wanted
    Last Post: 28th September 2007, 08:00 PM
