Results 1 to 10 of 14
Thread: AE86 4age 16v wiring problem????
    Member Dskew3's Avatar
    Feb 2013
    dustin
    Palmwoods
    Default AE86 4age 16v wiring problem????
    car: ADM AE86
    engine: 4AGE 16V conversion
    just bout a ae86 my auto electrocution was looking over the wiring and he said i need the engine fuse box for the 4age, also the other plug on the ecu (14 plug) and the ignitor. would any1 have any of these parts or is there ways around it. any help would be awesome thanks.
    You need a new autoelectrician... the ae86 has the spots in the fuse box for it....
    Feb 2013
    dustin
    Palmwoods
    he was only going by a wiring diagram, the fuse box the one in the car is off the 4ac and is different to the 4age by the book anyway and the 14 pin plug that goes into the ecu.
    Mar 2011
    Ali
    Yeah man, Matt's right.
    I've used the 4AC fuse box with a 4AGE bigport conversion.
    All I did was tap into the Alt wiring (as to ditch external voltage reg, and pick up on existing sig, lamp and 12V constant) and relay for injectors.
    You will need a COR for the fuel pump. (well it a good idea, and how you should do it)
    Most looms don't come with the body harness plug as its still in the car the loom is taken from.
    I used a SV21 4AFE Camry body harness plug, $7 from wreckers.
    Feb 2013
    dustin
    Palmwoods
    Ok thanks heaps ill let him no cheers guys
    Feb 2013
    dustin
    Palmwoods
    is there anyway of getting the other plug and harness from any where like a wreck or something.
    Mar 2011
    Ali
    Quote Originally Posted by Dskew3 View Post
    FTW
    SV21 Camry with 4AFE - ECU uses same body plug.
    EDIT: NOT 4AFE - 3/5SFE
    Feb 2013
    dustin
    Palmwoods
    Sweet I will check one out at the wreckers
    Veteran slide86's Avatar
    Huw
    Hills
    SV21 camry has a 3 or 5 SFE doesnt it?
    Mar 2011
    Ali
    Doesn't Wide body Camry have the 3/5SFE, like the next model up SXV10.
    Hmm, Actually you might be right.
    Its the 4cyl version of the Camry pictured above that I got the body harness plug from that fit Bigport ECU perfect.
    I just took ecu in with me, showed it to the guy, and went hunting through all Toyota's till found one of those magnificent POS pictured above.
    It didn't actually have a motor in it, I just assumed it was a 4A variant as the plug went straight in to my 4A ECU.
  1. (KE70: 4K-C --> 4AGE 16V Big Port) 12v Engine Power Wiring Q
    By bally in forum Technical - Questions
    Last Post: 16th February 2011, 04:37 PM
  2. sr wiring problem
    By eikots in forum Technical - Questions
    Last Post: 27th August 2010, 08:36 PM
  3. 4age wiring problem!
    By 15LIDE in forum Technical - Questions
    Last Post: 23rd August 2010, 12:02 PM
  4. 4age wiring problem!
    By sic86 in forum Adelaide & SA Events and Discussion
    Last Post: 17th April 2010, 10:08 AM
  5. SR Wiring Problem
    By bigm in forum Technical - Questions
    Last Post: 11th January 2010, 01:49 PM
