Results 1 to 10 of 13
Thread: HELP NEEDED 4AGE turbo microtech lt10s thermo fan wiring
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Default HELP NEEDED 4AGE turbo microtech lt10s thermo fan wiring
    Hey guys
    I have just recently purchased a ae86 with a 4age turbo convertion running a microtech lt10s and 4x ignition unit my prblem is the thermo fans arent working so im was planning on just rewiring them to the microtech. The fans are already running to a rely but there are to empty connections on that rely i just want to know if any one can explain what wires i need to run to that rely or what i need or should do
    would really help if anyone has some advice or diagrams thanks guys
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Just had another look i found one the the wires off the rely runs to the microtech but the other one runs to a fuse that then runs to the standard loom that goes in to an unknown place i havent traced that far back
    Mar 2011
    Ali
    I had issue's trying to get Microtech AUXfan to fire the relay at any given temp.
    Just wouldn't do it? Maybe I had it wired wrong, not sure, but have heard same issue from others.
    Been a while, but you will need hand control so you can go in and check screen set AUXfan on and set up temp.
    Spose to kick in 5deg before temp you set, but just didn't work for me.
    Warning, If you don't know what you doing, don't muck around with hand control, as you can accidentally change settings.
    You could bypass the LT ECU altogether and use thermo sensor/switch to trigger relay.
    Alternatively you could try Mircotech site forums and ask for help, but now days they are pretty shit, most threads go ignored.
  • #4
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I just use a standalone thermoswitch to control the fans......
    Very simple to took up, and is very effective......
  • #5
    Alex
    Wagga Wagga
    I have my thermo controlled by my microtech LT10s. Works fine, only thing is I can't remember how I wired it up haha!
    As JoJo said though, use a stand alone switch if you have problems. I used to use a Davies Craig switch back when I had a 5K in the car. To set it to come on at the correct temperature, wind the dial to max, then when the car gets to the temperature you want the fan to come on at, turn the dial back slowly until it triggers the fan to come on.
    I think you can get the Davies Craig thermo switches from Supercheap too.
    Alex's 4AGTE KE70
    Or so was thought...
  • #6
    JoJo
    ACT
    Tuggeranong
    Quote Originally Posted by blinded View Post
    Yeah, they stock the Davies Craig thermo switch kit from stupidcheap...
  • #7
    Sep 2012
    Tristan
    Koongal
    Quote Originally Posted by Gorgi View Post
    Hey guys
    to be honest i think its probably one of the easiest things to wire in on your microtech
    i had mine set to 84 degrees and works lol
    this is how your wire it
    pin 30 - 12v from battery (fuse)
    pin 87 - positive to thermo's
    pin 85 - earth trigger from microtech to control relay
    pin 86 - ignition power
    hope this helps
  • #8
    Sep 2012
    Tristan
    Koongal
    also if you wanna just try your thermo to see if it works at all
    go into your ecu setup screen and change your cylinder configuration and change it to 0 cyls this will activate your coils, injectors (without fuel pump running) and thermo on and off
  • #9
    JoJo
    ACT
    Tuggeranong
    ^^ All very true what you have said Tristan, with the relay example etc, but Gorgi is having the same problem as some other microtech users....
    Mine did the same as Gorgis....
    ie; All wired up correctly, setup correctly on ECU settings, but still nothing from the microtech trigger wire...
    Could be a common bug issue on the Microtechs.....
  • #10
    Mar 2011
    Ali
    Yup, AUXfan and Fuel pump prime, 2 common issues with microtech ECUs.
    I contacted Microtech about my issues, they told me to send it back to them.
    They said they were aware of the fuel pump prime issue, the diagram was wrong and fryed internals.
    I was running a surge tank with low pressure pump and 040 and had all ready rigged therms sensor switch so I ran with it.
    I never got the AUXfan to work, wired as above.
    I had a mate with the same problem.
    Looking back, for the money I paid, I would go Haltech now.
  • Page 1 of 2 1 2 LastLast
    1. connecting Thermo Fan with Microtech
      By Rice86 in forum Technical - Questions
      Last Post: 17th April 2010, 04:03 PM
    2. wtb ae71 thermo fan raditor hoses to a 4age
      By ke_70_blue in forum Cars or Parts Wanted
      Last Post: 17th March 2010, 10:51 PM
    3. Microtech LT10S & 4age ecu
      By munki in forum Car Parts For Sale
      Last Post: 12th March 2010, 12:41 AM
    4. Thermo fan wiring
      By quoccy in forum Technical - Questions
      Last Post: 17th October 2009, 02:09 AM
    5. whats needed to run LT10s on turbo smallport?
      By Nic19 in forum Technical - Questions
      Last Post: 2nd May 2009, 01:35 PM
