is it weird reaching for the gears with the wrong hand?
Would we have seen your G/F in anything here?
Hi Guys,
I recently moved to Hollywood as my girlfriend is an actor and have been driving a thirsty 350 powered Chev Tahoe. There are so many race tracks and Canyon roads nearby so I had to get a toy car. I searched for ages and test drove a heap of 4AGE powered ones until I found a car built by JSP Fabrication with a f20c.
I'm going to drive it until I need to have it inspected (90 days)then send it back to Sydney and part her out, or have someone do a RHD switch on it!
AP1 F20C
JSP AE86 S2000 engine mount set
TRD motor mount
JSP Custom wiring harness
BMI Racing Custom Mandrel bent stainless steel catback, Magnaflow turbo exhaust.
BMI Racing Custom Long intake with AEM filter
BMI Racing modified the exhaust manifold
Custom fit by BMI Racing; AFCO Racing Scirocco-Style Drag Racing Radiator
AFCO Racing Electric Fan and Aluminum Shroud Kit
Brand new Valve retainers, Valves, and valve seals
Resurface and clean head
New Honda motors stock head gasket
Gizzmo Phenolic intake Gasket
Brand New Honda head studs
255 walbro fuel pump
Honda S2000 CR belt
Duralast battery
Resurface flywheel
New Exedy stage 1 clutch and pressure plate
Powertrain Industries brand new custom two piece driveshaft.
Greddy Catch Can
OEM ECU
Braided fuel lines by Earls
Suspension / wheels / brakes
West alignment corner weight alignment
T series LSD Disc rear end
PROthane bushing kit
GTS sway bars
Fuel1000 adjustable pan-hard bar
AGX Camaro rear adjustable struts
MR2 refurbished manual rack
Brand new tie rod ends
Brand new steering knuckles
Front seals and bearing replaced
Techno Toy Tuning Front Coilover Conversion for AE86 Corolla 8kg spring
Techno Toy Tuning RCAs (Roll Center Adjusters, or Bump Steer Spacers
Techno Toy Tuning Delrin Manual Rack Adapter Bushings
Rear Swift 6kg spring
Cusco Camber plates
Cusco rear and front sway bars
Goodrich steel braided lines kit
RX7 front caliper adapter
Brand new and black coated FC3 caliper by centric parts
Mini cooper S front rotors and new rear rotors
Centric parts performance front and rear pads
Toyo Proxes4 195/50R15, New tires 95%
Front SSR mesh wheels 15x7
Rear SSR reverse mesh wheels 15x7.5
Chassis/Interior
Honda Blackberry Pearl
Solex Barrel locks
6x9 kenwood rear speaker
Pioneer front
AP1 cluster
JSP aluminum cluster vessel
JSP Custom Shifter
JSP aluminum Shifter plate
Power window
Power locks
JB lab Cup Holder
The lhd driving thing is ok but picking gears mid slide is just chance haha.
She has done stints in home and away but mainly arty short films and stage things which are too intelligent for me to follow.
Looks good man, only gripe with the setup is it looks like there is sfa room next to the accel pedal
and Trans tunnel, must be hard
skid it in Australia as is!
^^ this Ben. Otherwise let me know if you want a hand getting it done
