Results 1 to 3 of 3
Thread: T series Spline Size
    Oct 2010
    Quinn
    Woodridge
    Austown
    Default T series Spline Size
    Hey Guys, Canadian in Australia. I've got a VERY specific question for you:
    Backround: In North America we have two versions of the T series Differential (6.7").
    Versions:
    -Early: 23 Spline. Spline is identical to S (6.38) axles. I've fit spider gears from both onto each other with no Problem.
    -Late: ?? Splines. The late model AE86's came with an upgraded T (6.7") diff that was the same axle housing and carrier, but new axles with a larger splined area.
    Question #1: Did Australia Ever receive the larger T (6.7") axles?
    Idea: Back home in Canada, I raced a rotary powered Corolla wagon with an S (6.38") differential. I kept blowing up differentials until I swapped to a Mini Spool I found online. From then on the S (6.38") differential was super reliable with no problems!!! We tested my mini spool on Early (zenki) T series (6.7") Corolla GT-S axles and the spool fit exactly the same. The two different differential sizes used the same axle splines.
    Ideas:
    RA60's and RT141's are peanuts cheap now that I am living in Australia and I'd like to run my trusted mini-spool again. They are $40 brand new. We had a 5mge turbo pushing 290hp through a this mini spool in a S (6.38") differential, on 10" wide wheels for almost 2 years with no differential problems.
    Question #2: Is the RA60 T diff (6.7") the same 23 spline count as the North American Early (zenki) T series diffs? (6.7")??
    Thanks guys! For those who don't know. Legend/Dwarf cars in North America use Toyota differentials for racing. They built mini and full-spools to fit them:
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Vast majority of ADM T Series Diff's are 23mm, small axel or zenki
    Apparently some random townace or hiace model came out with live axel 25mm spline and drum brakes. From what i hear.
    Oct 2010
    Quinn
    Woodridge
    Austown
    That's ultra awesome!
    Question #3: rather than shipping this mini-spool from the States, is there any Aus ones available?
  1. T50 gearbox T series bellhousing 20 spline
    By beauc in forum Car Parts For Sale
    Last Post: 16th April 2010, 06:19 PM
  2. WTD: 23 spline axle!!
    By shinobi in forum Cars or Parts Wanted
    Last Post: 24th March 2010, 12:20 AM
  3. size of Filler & Drain plugs on s-series diff
    By biGtai in forum Technical - Questions
    Last Post: 28th April 2008, 02:07 AM
  4. ae86 s series stud size ?
    By reecegze in forum Technical - Questions
    Last Post: 29th March 2008, 02:07 PM
  5. Odometer spline?
    By grape_moosha in forum Technical - Questions
    Last Post: 4th February 2007, 10:17 PM
