Results 1 to 7 of 7
Thread: Hilux into t series
    Rob
    Armidale
    Default Hilux into t series
    Hi has any one tryed to fit a hilux centre in to a t series housing.
    Yes i no one is 6.7 and the other 8inch,but why couldnt it be machined a tad.
    Or may be fit hilux crown wheel and pinion to a t carrier?
    Ive been told it has been done ,but cant remember which way they went about it.
    Any one else hear of this??
    Just looking for a lower ratio maybe 4.77 or 5.1 hilux gear seems to be easy to get than t series gears.
    cheers rob
    Mt Macedon
    If it possible: No... Well anything's possible, but you're going to do some serious "adjustment" of the sheetmetal around the centre of the diff housing.
    Is it worth it just to get a ratio: No. You can get new T ratios for not crazy money.
    If you really want to be different then an E series centre will fit T housing with minor work. Then you can have a high ratio, but have no LSD options.
    Senior Member JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    A T Series 4.77 Centre is a few hundred dollars - I dare say you'd spend a lot more than that modifying a T Series housing professionally.
    Rob
    Armidale
    Thanks guys ,it has been done but as you say may not be worth the effort.
    Few hundred in australia ,please tell??
    rob
    Veteran Skylar's Avatar
    Ken
    http://www.weirperformance.com/finaldrivegears.html
    Not quite a few hundred but cheaper than doing all the work you proposed.
    Sep 2010
    Daniel
    Sydney North
    I always forget that people associate a few hundred with $200 :|
    ^^ Weir is what i was talking about -
    4.30, 4.778 Ratios $318.60
    **NEW** 5.13 ratio $389.00
    Veteran slide86's Avatar
    Huw
    Hills
    Quote Originally Posted by JDMWheels View Post
    this is a corolla forum remember.......
  1. (VIC) G series Hilux diff forsale
    By BMXB in forum Car Parts For Sale
    Last Post: 23rd July 2012, 04:36 PM
  2. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  3. G series hilux diff centre non LSD
    By reecegze in forum Cars or Parts Wanted
    Last Post: 21st April 2012, 03:05 PM
  4. 98 hilux diff... G series
    By 57ompa in forum Car Parts For Sale
    Last Post: 13th April 2011, 09:20 PM
  5. Hilux g series diff
    By otanica in forum Cars or Parts Wanted
    Last Post: 26th January 2010, 01:28 PM
