Results 1 to 10 of 11
Thread: 4agze problems... SA
    Jul 2012
    andrew
    Aldinga Beach
    Default 4agze problems... SA
    picked up myself a ae82 with a 4agze conversion a month back, was going sweet until half way to work one day and it started the sound like a lawn mower. still runs but sounds like running on only 2-3 cylinders and fuel is leaking straight out of the flange between the headers and exhaust.
    couple of mates think its injector problem of maybe an ecu problem.
    just wanna know if anyone has any ideas as to what the problem could be?
    Veteran slide86's Avatar
    Huw
    Hills
    fuel is leaking out of the flange between the headers and exhaust???? really???
    if that is so, then you have an injector stuck open or one cylinder has no spark
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    Like said above, check injector O rings could be wedged and injector stuck open which can cause a hydraulic lock in the combustion chamber if that happens say goodbye to your engine.
    Jul 2012
    andrew
    Aldinga Beach
    yep really and it is a fair bit coming out, ill try upload a vid tomorrow. ill see if i can work on it tomorrow and have a look at the injectors.
    Jul 2012
    andrew
    Aldinga Beach
    ok so i took the plugs and injectors out the 2 furthest away from the timing belt where wet, but the injector o-rings on all 4 look to be good...??
    Sep 2012
    Tristan
    Koongal
    Quote Originally Posted by wags View Post
    it isn't coolant at all?? if it is fuel thats quite dangerous!
    how quickly does this happen?
    Mt Macedon
    From factory, injectors 3&4 (the ones that are leaking) share a trigger from the ECU. If this wire got shorted to ground (either somewhere in the loom of if the ECU shat itself somehow) then the injectors would stay open and drop lots of fuel into the inlet.
    May be a long shot, but is easy to check with a multimeter.
    Jul 2012
    andrew
    Aldinga Beach
    It's definitely fuel, happens as soon and I turn the engine over. Hen I think you might be onto something! Ill have a look at that tonight
    Sep 2012
    Tristan
    Koongal
    i would put a noide light on the injector harness of 3 and 4 and see if it continouly stays lit up or flashes or even test light
    Jul 2012
    andrew
    Aldinga Beach
    Wowsers... Found the Ecu then discovered the messy wiring, wiggled the Ecu plugs around put my injectors back in then started her up and bam! Back running on all 4 runs pretty sweet... Joys of dodgy engine conversions haha thanks for all the help guy much appreciated
  1. 4AGZE Injectors, SA.
    By dreny... in forum Car Parts For Sale
    Last Post: 1st September 2010, 10:57 PM
  2. 4agze CAS signal problems with Haltech e8
    By lloydious86 in forum Technical - Questions
    Last Post: 4th October 2009, 06:22 PM
  3. 4agze problems
    By drew86 in forum Technical - Questions
    Last Post: 16th September 2008, 01:21 AM
  4. 4agze boost problems
    By samuek in forum Technical - Questions
    Last Post: 29th April 2008, 04:42 PM
  5. 4agze conversion problems
    By AE86.cn in forum General Topics (No Technical Questions)
    Last Post: 13th March 2006, 04:10 PM
