Results 1 to 3 of 3
Thread: Coil over conversion
    Junior Member wild_70's Avatar
    Corey
    Bendigo
    Default Coil over conversion
    Ok, so I'm currently converting rt132 struts to coilovers for my ae71. Here's my numbers that I have, id just like to make sure I'm on the right track.
    Sprung ae71 struts from the bottom of the strut to the top of the top spring perch is 550mm, unsprung 650mm
    New mr2 inserts are about 560mm unsprung and I think about 520mm sprung.
    Now I got the 520mm from saying my 7kg springs move about 40mm providing the front of a ae71 is about 300kg each side.
    Am I sniffing too many fumes or am I correct?
    Plan is to make the highest point of my coilover about 30mm lower than standard.
    Corey
    Rob
    Moorabbin
    Hi Corey,
    You also need to take into account the spring preload when you are taking these measurements.
    You will only get the 40mm compression of the strut under 300kg of weight on it if you have 0 preload (ie if the spring is only just snug in the strut)
    If you want to adjust it any lower than that you will have the spring non-captive when it is unloaded, there is some chance it could slip off its seat.
    but if your measurements of the open length of the strut are good then your sums seem fine (assuming the 0 preload part).
    If you preload it at all then the car would sit a bit higher than the 30mm reduction you are aiming for.
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    Quote Originally Posted by RobertoX View Post
    Has this actually happened to anyone? Curious.
  1. How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    By Fine Taste in forum Technical - Questions
    Last Post: 5th August 2014, 07:50 PM
  2. Replies: 0
    Last Post: 24th June 2012, 12:57 PM
  3. Replies: 2
    Last Post: 6th April 2010, 12:01 PM
  4. dizzy - coil pack conversion
    By tim.duncan in forum Technical - Questions
    Last Post: 25th June 2008, 06:20 PM
  5. aluminium spacers for struts in s13 front coil conversion?
    By phoenixrx7 in forum Technical - Questions
    Last Post: 19th February 2007, 07:30 PM
