Results 1 to 4 of 4
Thread: Crushed Panhard rod body mount. Suggestions on how to fix
    Walte
    Goldcoast
    Default Crushed Panhard rod body mount. Suggestions on how to fix
ID:	28231Click image for larger version.
    So I was driving last week and kind of stacked it.
    I bent my axle, punched a hole in the floor from the tyre, destroyed the hole brake setup on the right side and took a chunk out of the my wheel
    This was all ok as it's easily replaceable but I also crushed my panhard rod body mount (pictures below)
    I was wondering if anyone has done this before and how did they fix it?
    I have a couple of ideas so far how I can do this;
    Chop off the crushed section and have someone weld another one on (I already chopped this part out of a car I stripped on the weekend). If anyone would like to weld this bit in for me i could give them cash, beers, help with mechanical or a little bit of wiring or I could get you cheaper parts when you need them. Or just anything lol
    Or
    Chop the bit off and spread the cut out piece so it slides over it and then fasten it with bolts:/
    Or....
    Any suggestions to fix this would be much appreciated
    I'm located in southport
    Walter
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Similar thing happened to mine. Pics do not quite show , but if the housing that the pan-hard bolts to chassis is not to crushed (if it is you will have to straighten it or replace ). Then get a three sided box piece of steel , cut to suit the shape . bang it into place and weld ( not bolt ) it . 2 pics of mine
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Walte
    Goldcoast
    Cheers for the idea man, it look good!
    Soo who on the goldcoast wants to come around with a welder
  • #4
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    had the same thing happen to me i just cut a panhard mount off a ke70 then welded it in wasn’t that hard surprisingly
  • Similar Threads
    1. Panhard Rod Mount Buckled =S
      By bally in forum Technical - Questions
      Last Post: 18th May 2011, 08:48 PM
    2. Broke my panhard rod mount off
      By D4NI3L in forum Technical - Questions
      Last Post: 15th December 2009, 10:12 PM
    3. panhard rod
      By DriftPlease in forum Technical - Questions
      Last Post: 11th October 2007, 07:26 PM
    4. Panhard rod
      By eightsixboy in forum General Topics (No Technical Questions)
      Last Post: 10th June 2007, 08:29 PM
