Results 1 to 3 of 3
Thread: More advice than a bug.....
    Member filfilfil's Avatar
    Phil
    Just South
    Default More advice than a bug.....
    Hi, I was looking for some advice and wondered if you knew the answer....I know its a bit off track!
    We are looking at using vbulletin for our intranet forums (based on my experience here) and are looking at using an external source for our user lookup (ldap to Active Directory). Have you seen this work or do you just use the products local users?
    fil
    Stern but now fucked off...
    May 2005
    Nick
    I'm not sure if VB supports any type of LDAP sync at the moment, but if you're running a SQL server, it would be very easy to have it syncing with the vb_user table
    A SQL Script piggybacking on a cron job that ran every 6 hours would probably do the trick.
    It'd be far easier to write a custom login page that uses ntlm auth that queries ad directly. Replicating the directory can be a pain in the proverbial and is the old way of doing it.
    or look into a form of Identity management software
  1. Is my computer infected with the Y2K bug?
    By biggo in forum Tech and Gadgets
    Last Post: 24th August 2013, 08:53 PM
  2. Bug: People cant private message me anymore.
    By Patric in forum Bug Tracker
    Last Post: 4th November 2011, 04:09 PM
  3. Bug Reporting
    By Nicko in forum Bug Tracker
    Last Post: 30th April 2011, 11:47 PM
  4. Replies: 2
    Last Post: 22nd April 2010, 10:00 AM
  5. Caught the 86 bug again want another one
    By AEA-386 in forum Cars or Parts Wanted
    Last Post: 10th January 2010, 02:02 AM
