Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: W55 to 4AGE 16v
    Senior Member Mika's Avatar
    Jun 2011
    Daniel
    Default W55 to 4AGE 16v
    Hey Lads,
    I have had a look around in the tech section for info on this. Have read a few ways to do it. I have a complete T50 gearbox I bought with an engine conversion that turned out to be a dud. I have heard the T50's are a weak box when it comes to giving them a bit of a hard time. What is the most common way to get the W55 to fit onto the 4AGE?
    Will all I need is a W55 box, adaptor plate and a T50 bell housing? Plus a clutch etc? Or is it more complicated than that?
    Cheers.
    Daniel.
    Veteran willa's Avatar
    Will
    Northern 'burbs
    My list:
    W55 (need shifter, fork, bearing carrier)
    Nite parts bell housing
    Rt142 slave
    Custom clutch line (as it moves slave to drivers side)
    custom clutch (depends on flywheel, but basically a re-spline of a 4age clutch will do)
    Custom cross member
    Custom tailshaft (or front half from ra40(?) And rear half from which ever diff you're running)
    There is a bit to it, but re-sale is usually good.
    Will.
    SuperFunHappySliders
    SR's are ghey.
    Jun 2011
    Daniel
    Thanks heaps dude, Looks like ill be saving then.
    My T50 wouldnt let us down change into second gear. Goes in fine, just cant down change to it. Got the gearbox pulled down and 2 gear synchro is totally stuffed.. Overall the box is pretty well worn.. But yeah. So getting hooked up hopefully to get some new synchros in there just to get it going for now. It will be a bit of an expense to get in there but well worth it in the end as you say. As T50's dont last with a bit of a hiding hey? Blow a T50 a few times, might as well put in a W55 setup.
    Are the W55's good for it?
    Thanks again Will.
    Will
    Northern 'burbs
    No worries! Yeh mate they match their w58 counter parts for strength. what engine setup you running?
    SR's are ghey.
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    NA 16v a t50 will be fine.
    my 20v with a button clutch didn't blow a t50 in 18 months of drifting.
    Jun 2011
    Daniel
    Quote Originally Posted by Jacobxxx View Post
    Cheers Pecky. Will run it and see how I go.
    Nathan
    Lilydale
    I guess it depends how you treat it, i have had no luck with t50 boxes, syncros dont seem to put up with much abuse, quite a few times i've broken teeth of 2nd gear aswell, was only using stock bigport.
    Going to W box was the best thing i ever did! no issues yet even with turbo 4ages ect.
    Id recommend going W if you can! just my opinion
    Senior Member JDMWheels's Avatar
    Sep 2010
    Daniel
    Sydney North
    I have a Niteparts Bellhousing here if you decide to go W5X! Brand new =)
    Jacob
    Bangalow
    Depends on oil you run as well!
    Jun 2011
    Daniel
    Quote Originally Posted by Sprinter86 View Post
    Cheers mate! I do work away, so I really wont be driving it as much. Plus on the West Coast we don't get as much drift track time here as you East Coasters. I'll just run the T50 for now. See how she performs with how I drive and how often I drive it. A W55 conversion will be on the cards later on down the track when I put a more mods onto the 4AGE. Good to hear thee W55's put up with turbo 4AGE's, that will be the plan later on down the track for mine.
    Quote Originally Posted by JDMWheels View Post
    Thanks mate, as much as I would love to start collecting bits for for the conversion now, I'll see how the T50 goes. Plus they are a little out of my price range at the moment.
    Cheers for all the advice lads, greatly appreciated.
  1. VIC: AE71 Panelvan Drift car part out! w55, hilux, 4age ect.
    By Sprinter86 in forum Car Parts For Sale
    Last Post: 13th February 2013, 10:05 AM
  2. VIC: 1984 white AE71 Panelvan ! w55, hilux, 4age ect.
    By Sprinter86 in forum Cars for Sale (Toyota Only)
    Last Post: 23rd January 2013, 11:29 AM
  3. 4age 16v small port head 4age dizzy for carbies
    By dehney in forum Car Parts For Sale
    Last Post: 2nd November 2010, 07:15 PM
  4. 4age 16v vs 1.8 7age 16v
    By stx-16 in forum Technical - Questions
    Last Post: 11th November 2009, 02:14 PM
  5. 4age 16v JDM and 20V ST + heaps of other 4age stuff
    By oz_eight6 in forum Car Parts For Sale
    Last Post: 6th October 2009, 02:14 PM
