Results 1 to 4 of 4
Thread: 4age 16v valve adjustment needed?
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Default 4age 16v valve adjustment needed?
    Hello,
    I'm in the process of replacing the headgasket on my 4age 16v ae86, during the process of taking the head off, some of the valve caps came off the head because I had it tilted so I could remove the intake manifold.
    What I'm asking mainly is do I need to check the clearances for each? I'm not very familiar on how to adjust these type of valves. I just bought the car a month ago for $500.
    I've tried searching google and other forums but I can't really get an answer.
    I put them back in the order they were to the best of my knowledge.
    Thanks for any help.
    Car - AE86
    motor / part in question - 4age
    problem - Question
    occurs/started when (if applicable)-
    personal situation (if applicable)-
    Jun 2011
    james
    oxford
    general area
    England
    A fundamental of good engine performance is having the valve clearances correct, generally the 4age does not need re-shimming very often so it is worth
    doing right.
    So yes you do need to check the clearances.
    Fairly straightforward to do and the only slight issue is changing the shims with the cams fitted as the edge of the cam follower needs to be depressed
    to allow the shim to be removed. (in your case as the head is not fitted you can easily measure the clearances and just remove the cams to change
    the shims)
    As you already have the head off of the engine then you can do the clearances on the bench, just allow some space under the head face for the valves
    to move into. Turn the camshaft until the heel (circular part) of the cam is above the shim and measure the clearance with some feeler gauges.
    Make a note of the Valve number and whether it is inlet or exhaust and the clearance.
    Do this for all 16 valves.
    http://www.ae92gts.com/ae92gts_valve_adj.html
    Mar 2013
    Troy
    WA - Washington
    TACOMA
    United States
    Quote Originally Posted by tottacrolla View Post
    doing right.
    the shims)
    One thing I forgot to mention is the head is back onto the engine currently. And you adjust the clearances by moving the shims around/buying new shims?
  • #4
    Jun 2011
    james
    oxford
    general area
    England
    Quote Originally Posted by Tman312 View Post
    Correct.
    Be careful turning the cams if the cambelt has not been fitted and timed.
  • Similar Threads
    1. Replies: 11
      Last Post: 12th February 2012, 03:57 PM
    2. WTB:valve springs for 16v 4age smallport
      By trd4ag in forum Cars or Parts Wanted
      Last Post: 30th December 2010, 10:29 PM
    3. Replies: 10
      Last Post: 22nd July 2009, 10:19 PM
    4. Valve adjustment 4K-C
      By Ksevn-T in forum Technical - Questions
      Last Post: 19th May 2008, 01:30 AM
    5. setting valve timing on 4a SOHC - help needed
      By Maxhag in forum Technical - Questions
      Last Post: 13th January 2008, 03:11 PM
