Results 1 to 10 of 17
Thread: Wheels & Offset
    Default Wheels & Offset
    Hey,
    I am just wondering if anyone has put these size wheels with offset onto a ke70 - with only modifing the standard guards.
    Front - 15x8.5-9
    Rear - 15x9.0-1
    If you have could you post up a picture or some information regarding this, even if you have kinda close to these specs.
    Cheers barnzy
    Veteran johl's Avatar
    Johl
    will be good fitment. will need a bit of work but that depends on alot of variables (ride height, suspension, lca's, tyres) i run 15x7.5 0 offset all round and i think the same offset in an 8 would be perfect
    Senior Member adam's Avatar
    Adam
    Car below has 8" -15 up front and 8.5" -25 out back. Not too sure on suspension mods though.
    Your front wheels will sit pretty much the same as that, rear wheels will be sitting in 17.7mm more compared to those. All assuming he's running standard or 86 suspension bits.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
    thanks cobber!
    Veteran Konakid's Avatar
    Henry
    Eastern
    Flaring front and rear, stock LCA's and 195/50's should make them fit.
    Senior Member JDM_KING's Avatar
    jake
    West Side
    i have ssr long champ rims but wanting more dash,which rims would fit on a ae86 levin that would have deep dash?
    JDM King, there are longchamps out there with heaps of dish, just try to find some wider ones.
    ive got some 13x7 and 13x8 SSR mark2's sitting at home that need a polish so i can put em up on my ke25... seeing that E7 has inspired me
    性交を愛する
    Someone with the name JDM KING, knows nothing about JDM Wheels.
    Makes perfect seance.
    Veteran slydar's Avatar
    Dimitri
    the yellow car has 14s though. 15s will be tougher.
    id honestly say thats too big for a ke.. looks like a monster truck.
    Quote Originally Posted by slydar View Post
    agreed...14's on a ksev ftw
  1. Replies: 1
    Last Post: 6th October 2011, 05:20 PM
  2. Replies: 4
    Last Post: 30th May 2011, 10:33 PM
  3. After a set of old JAP Wheels 15/16 or newer wheels in neg offset
    By liquidlime in forum Cars or Parts Wanted
    Last Post: 7th October 2010, 10:11 PM
  4. Replies: 0
    Last Post: 24th September 2010, 02:04 AM
