Results 1 to 6 of 6
Thread: Earthing kits
    Member Anthony13's Avatar
    Jun 2012
    Anthony
    Yarra glen
    Default Earthing kits
    Hey all I've had a problem with my s14 earthing out on something I fixed the wires that melted and ran an extra wire of them to some metal part of the body to try and prevent it from happening again, but I was told to get one of them earthing kits for it and I heard that car can run a lot smoother and more responsive as well as noticing more brightness form headlights and a better crisper sound from stereo! So what I want to no is yay / nay?
    And what do you do if your battery's in the boot?
    Senior Member pt_y2k's Avatar
    Paul
    What your gonna notice will be minimal if any...I'd spend the money elsewhere and just make sure your original grounds from battery to chassis,chassis to engine block are good clean surfaces and connections.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    every ecu runs on it's own regulated 5 volt power supply, unless your ignition is getting power it's not going to make anything run different. All you want is a few good earths- one of them subframe to as close to the starter as possible
  • #4
    Mt Macedon
    Quote Originally Posted by Anthony13 View Post
    All classic, unable to be measured, bullshit claims about earthing kits/voltage stabilisers/energy polarisers. As mentioned, just make sure your earth cables are a decent size and have good contact.
    Also adding some punctuation to your post would make it far, far easier to read and understand.
  • #5
    Jun 2012
    Anthony
    Yarra glen
    Thanks for the advice on this peeps!
    And I didn't think that people would care about bad punctuation, you obviously have nothing better to do!
  • #6
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    people do them on evo's cables everywhere, they shit house, same as those "voltage stabilizers" RUBBISH
  • Similar Threads
    1. Jdm Ae86 Ultra Leads Earthing Kit
      Last Post: 3rd March 2012, 11:12 AM
    2. FS: Full coil over for AE86/KE70, Aftermarket 4AGE ECU, Earthing kit
      By charlie_keto in forum Car Parts For Sale
      Last Post: 6th July 2010, 07:47 PM
    3. 16v earthing
      By Tim.duncan in forum Technical - Questions
      Last Post: 29th July 2009, 11:41 PM
    4. earthing points on a ke70
      Last Post: 18th May 2009, 09:26 PM
    5. earthing kits????
      By ae86dave in forum General Topics (No Technical Questions)
      Last Post: 22nd May 2006, 12:45 PM
